Question about GE WNSE6280BWW Top Load Washer
Non-spinning washer My washer will not spin on it's own. We replaced the drive belt. After we replaced the belt we reconnected everything and tested. It spun for 5 seconds, creaked, and then quit. The belt was warm to the touch. When I tried to turn the tub manually the belt moved fine. Can you help? My washer is a Frigidaire model #FWS445SFR0. My washer goes thru all the cycles OK except spin it make a noise like its going to spin and all the water drains out but no spin
    President:
  • 1,902 Answers
Have you checked the motor? Make sure that the motor is turning properly and also make sure that your belt it not to tight. It should have some give in it. If none of that works then look at the main bearing under the pulley on the drum
Posted on Feb 10, 2009
The washer drum wont spin.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 29, 2010 | Kenmore HE2 Plus Front Load Washer
Won't spin
If your washer is not spinning you need to check this part.
  1. Test the lid switch
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt(belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
Mar 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer wont spin out
  8. Test the motor
Mar 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer won't spin
You need to check this part of you machine:
Test the lid switch
Test the motor
Inspect the pulley
Check this parts this are the some cause to not spinning.
Dec 10, 2009 | Maytag Neptune Washer
Won't spin, won't drain
Hi...
If your washer does not drain, you need to check this:
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
If it does not spin check also this:
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not spin
many m/c s has aswich or additional program called "no spin"
pleas check it 1St>
thanks
Jul 11, 2009 | Maytag Washing Machines
Full of water,won't drain or spin
Dear customer,
        we recommend u to do the follwoing checks on ur washer
  3. Test the lid switch (some models)
  5. Inspect the drive belt (belt drive only)
these are usually performed wen water doesnt drain out and for the agitator not spinning the problem's root can be known by..
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
plz rate this solution.. for more details on self check try http://www.acmehowto.com/howto/appliance/washer/washer.php  good luck..
Apr 08, 2009 | Washing Machines
Washer does not spin
Hi, There are several causes for this problem. Check these.
  • No spin at all: the lid switch is fried. You test it with your meter.                                  There will be a motor which spins the washing machine's drum.                                              If you don't hear the motor running, then its the lid switch which would have been broken and needs replacing. A bad lid switch wil interrupt the spin cycle.
  • In the Whirlpool washers, a common problem is that the lid plunger stops making contact with the lid switch. Use a pen to manually press the lid switch actuator (with the lid up, duh). If the washer spins...well, you know the rest.
  • Older (belt-drive) Whirlpool: the spin solenoid is burned out or has cut wires. Ohm out that solenoid (20-30 ohms) and test with a test cord. Make sure the wires are intact by giving them a little tug. If this is OK, you may need to adjust/replace the basket drive.
  • Timer is fried. On older timers, it's sometimes possible to run an external jumper to replace the bad internal contacts. Usually, however, the entire timer must be replaced. The only way to confirm is to use your meter and wiring diagram.
These are the causes that have to be inspected. You can also visit this site www.whirlpool.com/custserv/index.jsp
Hope my info solves your problem, Thanx for using fixya, Good luck.
Sep 29, 2008 | Whirlpool CAM2752KQ Top Load Washer
Not spinning
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Jun 14, 2008 | Washing Machines
Non-spinning washer
Do you hear the motor running when it doesnt spin? Is the belt still over the idler pully between the drive pully and motor pully? Does the lid switch operate properly? Need a little more information if you can. Give me a shout back, and we'll figure it out. Jim
Oct 31, 2007 | Washing Machines
GE WNSE6280BWW Top Load Washer Logo
149 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
