Question about APW Wyott Sport & Outdoor - Others
93 polaris xlt tripple wont run to full potential
I got a 93 polaris xlt tripple the guy i got it from had it out this year(ran fine). the reason he got rid of it was because the exhaust melted a hole in the belly pan and took out a shock.he let it sit for about 3 weeks til i got it even still though i drained all the gas out of the gas tank and cleaned the carbs.it took a bit to get running. it runs good with out a belt on but when you put the belt on and take it off the stand it bogs out like its only running on two. me and my brother have spent 3 long days trying to figure it out we just cant prior to buying the sled we checked compression all were at 90. thanks
The issue I had with my 94 was due to an oil adjustment, wich you can find below the carbs. It ran great at full throttle but once it sat at idle, the plugs would get wet and the same type of bog would accure. Get new plungs and make sure all three are firing first, if they are then the oil adjustment is off. If not sorry to say but you may have a bad coil.
Posted on Mar 18, 2009
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
Are there any other booster pumps that I can use to run my pool cleaner? I had a Polaris bp4-60 for 7 years, it finally failed. Replaced it with same model. Ran for few mins then shuts off then restarts....
I think Polaris should refund the purchase price on these pumps. I changed the breaker, the whip, and upgraded the outlet (using 110). The dealer exchanged it for me, but would not give me a refund, and I had the same issue with the second motor. I used a Hayward 6060 pump as a replacement. Everything works fine.
Jul 04, 2014 | Polaris Pb4 - 60 Booster Pump
Polaris xlt engine troubles engine will start but will only keep running if i play with the choke
had same problem just this week mine would only run in choke positions simply die in run position i ened find i very small crack in the stem of my fuel filter believe it ir not so i removed it and ran a new line without filter straight in just to see what would happen and it worked ran like a champ put new filter today and still flawless runs great and idles perfect was told it simply was sucking in air threw that small crack witch would screw my fuel flow sounds crazy but hey easy fix you never know
Feb 01, 2011 | Polaris New Genuine Polaris Snowmobile...
I have a 1997 polaris indy xc 600 tripple that is getting to much gas and the crank keeps filling up with gas. It wont even start.
bad needle and seat in carburetors allowing gas leak by needle in carbs. Turn off gas when not in use and will help get by until you can replace them
Dec 28, 2010 | Polaris New Genuine Polaris Snowmobile...
1997 Polaris XLT Triple. Do I really need to pull
I have 1995 and a 1997 XLT. i have rebuilt the recoil on the 95 and all it takes is the few bolts to take off the cover and take the pipe off. if the 97 is any thing like my dads 94, you may have to pull the engine up a bit, the bottom left bolt cant fully be backed out with out hitting the side of the belly pan retainer, all it takes to pull the motor up is one nut in the back of the motor mount, and one bolt off the front, and it will tip up enough
Jan 10, 2010 | Polaris New Genuine Polaris Snowmobile...
Got a used polaris xlt that has"ran in 6 years got it running but it doggs out at half throtle what can i do?
that sounds like a coil is gone bad and you are running on 2 cylinders, that or the carbs are being starved or flooded, many posibilities
Nov 29, 2009 | Polaris New Genuine Polaris Snowmobile...
Sport & Outdoor - Others Logo
272 people viewed this question
Top APW Wyott Sport & Outdoor - Others Experts
Are you an APW Wyott Sport and Outdoor - Other Expert? Answer questions, earn points and help others
