Question about Polaroid 1720-7 Remote Control
My Polaroid remote control won't work.
Worked fine for months, but now will not turn tv on or off. I have Direct and only use the Polaroid remote to turn the tv on and off.
  • monte123 Mar 28, 2009
    volume woke on off not
  • 360 Answers
First we need to know if the remote is working. Heres the "secret" way to check a remote. Use a cell phone w/camera.
  • Set the cell phone to camera
  • while watching the camera screen and a known good remote, aim the remote at the lens and press a button (volume works well) on the remote (not a device button ie; sat,tv,vcr,etc). You should see lights turn on/flash. Now you know your camera can detect IR light.
  • Do the same again with the remote in question. If there is no IR light output, the remote is the problem. replace the batteries, ensure good battery contact, retest the remote.
If the remote is working then the problem is in the unit.
Let me know what you find.
Neat trick, huh? Please take the time to rate this.
clarkco
Posted on Feb 10, 2009
I moved my drop down TV to another floor and had FIOS add a line so I could hook it up. I can only get channel 3, no picture. I've tried the polaroid remote that came with the TV and also the remote that came with the box I needed to hook in to the FIOS system. Which remote should I be using? Is there a code or something I need to program in. The TV was working fine until I moved it. Thanks for your help! I definitely can't afford to buy a new TV, and FIOS is charging me $140 for installation of the line.
Krissy in Virginia
Posted on May 17, 2009
Polaroid FLM-373B not responding to any ir remote controls. Neither the OEM one or a Direct TV universal remote that has supposedly been 'programmed' for the TV.
Hi there
My first reaction is to disconnect the power supply for 5 minutes (often works wonders) With the power on again look for the function knobs on the TV itself. They are usually down in the right hand corner on the front. They have the same function as the knobs on the remote.
Give it a try.
Good luck
Kolbrun
Feb 20, 2012 | Televison & Video
Tip
Polaroid TV DVD Combo Remote Codes Can't find a code to program your universal...
Can't find a code to program your universal remote to control your Polaroid HDTV / DVD combo? Can't find a listing for Polaroid DVD in your remote control code list?
Many manufacturers recycle remote control codes, so often the best solution is to use the code search function of your universal remote.
Here are some remote control codes that have worked to control Polaroid HDTVs:
  1. My 19" w/DVD uses the following Mitsubishi code: 10178
  2. Dish Network remotes: 627, 659, or 688
  3. DirecTV RC64 remote control revealed a code of 10835. This means that 10835, 0835, 835 or some variant many work with many programmable remote controls. On my DirecTV DVR system, this was indicated as a Moxell and/or Motorola TV code.
  4. Use the mitsubshi tv codes they worked for me.
  5. Try Element codes if they are listed in your remote code list.
I hope that helps.
_____________________________________________
Polaroid HDTV Manual Download
Polaroid HDTV Service Manual Download
on May 02, 2010 | Televison & Video
Tip
Polaroid HDTV Remote Control Codes
Polaroid HDTV Remote Codes
Can't find a code to program your universal remote to control your Polaroid HDTV? Can't find a listing for Polaroid in your remote control code list?
I hope that helps.
I have the same problem..
U can also tries cleaning the batteries polarities with some WD40.
Clean the IR LED for the remote,and the tv.
Aug 19, 2009 | Polaroid 1720-7 Remote Control
Tip
Polaroid DVD Combo Remote Codes Can't find a code to program your universal...
I hope that helps.
on May 01, 2010 | Televison & Video
Element tv remote code flx-2210
For the Direct White remote it is 10178
Jan 18, 2008 | Televison & Video
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Remote control problem
Have you tried "One for All" universal remotes?
Jun 10, 2007 | Polaroid 1720-7 Remote Control
Televison & Video Logo
2,269 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
