Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
DC17 doesnt move on floor good
We recently replaced the belt and filter on our DC17 and now it seems impossible to push it across the floor. I am wondering if I put the bottom plate/part on wrong? It doesnt glide across my wood floors like it use to.....it seems to make a scrapping sound now.....is it suppose to adjust? I have taken it off and replaced it 4 or 5 times to no relief.... Is it because we took it apart and cleaned everything and now it is just so strong? I liked it better when it was clogged and moved....I have to use both ams to push it across my area rugs...HELP!!!!!!
  • innominato Mar 14, 2009
    It seems like the vacuum action is sealing the bottom on the floor and causing the resistance to movement because if there are irregularity in the floor that break the seal there ir moves easily.
  • innominato May 11, 2010
    I have a DC17 with the same problem and I have checked all the obvious
    and believe my sole plate is installed correctly. Several other user
    had the same problem and I have not found a solution anywhere.
    Did you fix yours?
Also be sure the 2 springs are still underneath. I think those help level out the vacuum on various surfaces.
Posted on Mar 27, 2009
    President:
  • 389 Answers
Yes, it certainly sounds as though you haven't re-fitted the sole-plate correctly. On most models, the sole-plate has three tabs at the front, and these locate in slots in the bumper bar at the front of the body. These tabs must be in the slots before you tighten the three locking screws. You need to hold the rear of the sole-plate up while pushing the tabs in to the slots, then press down on the rear and tighten the screws. Just the fact that you cleaned the machine will not be the cause of the problem.
Posted on Feb 11, 2009
My change floor setting on/off button blinks and it is really hard to push but it doesnt **** up like it use to either.
I'm sorry to hear you're having difficulties with your Dyson cleaner. From your description, it sounds as if you have a DC28 Animal, rather than a DC17 Animal. If the cleaner seems hard to push, and an indicator light is flashing, you may have the brushbar set to a level too low for the carpet you're trying to clean. Try raising the brushbar to the next height available on the selector pad.
If you need any further assistance with your Dyson, please get in touch with us directly - you can call us free on 1866MYDYSON.
Kind regards,
Jack
Dyson Online Customer Support
Jul 15, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Our Riccar SupraLite Upright Vac used to glide across the floor so easily, but now we have to push it pretty hard. This just recently started. What can be wrong?
Suggest you check the wheels to see if they are moving freely. Also check the beater brush to see that it is moving freely. Be sure the belt has not broken. If it has, replace with a new one. Also take the time to clean the beater brush of any debris and spray a little WD40 on both ends of the beater brush axle.
Sep 12, 2010 | Riccar 8955 Upright Vacuum
I don't get much suction from the hose on my DC17 All Floors. I don't see any obtacles in the hose. The suction when upright is fine.
The way your Dyson DC17 is designed, there is a suction divert mechanism that diverts the suction to floor when the vacuum cleaner head is pushed down, and then back to the hose when the vacuum is in the upright position. If you are getting suction from the hose when the vacuum is upright, but no suction after the handle is reclined, this is actually the normal function for the Dyson DC17.
You can check to see if the filter is dirty. The washable filter on your Dyson DC17 is located directly underneath of the dust bin of the vacuum cleaner. After removing the dust bin, lift straight up on the part the bottom of the dust bin rests on. This is where the pre-motor filter is located for the DC17 models. If this filter is not cleaned on a regular basis, then it can start getting clogged, and you'll notice a loss of suction on the vacuum cleaner.
If you have further questions, please visit the link below where you may download the instruction manual. There are some trouble shooting guides at the back of the manual that you may do to try and diagnosis this further.
Dyson DC17 All Floors Instruction Manual:
http://media.dyson.com/downloads/us/floorcare/manuals/dc17_opmanual_usa.pdf
If this was helpful, please be sure to rate the repair as helpful by clicking on the thumbs up icons on the top of the repair.
Thank you very much,
Chris Jones
GoVacuum
Mar 23, 2010 | Vacuums
My Dyson dc17 turns on, but when you want to vacuum, the roller doesn't move
You need to replace the belt. Here is the belt you need and a manual you can view which has instructions:
Dyson DC17 Belt and Manual
Jan 17, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson DC17 makes a loud noise when i tip the handle down to make the brush spin on the floor?
Loud noises are usually caused by worn belts, unbalanced roller brush or debris in the roller brush. Check these things. Here is a link to the belt you need:
Dyson DC17 Replacement Belt
Nov 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson DC17 has a noise in it when in the carpet mode and not when in the bare floor mode. HELP
Did you clean out the roller brush and replace the belt? If you haven't done that I would give it a try. Here is a link to the replacement belt you need:
Dyson DC17 Belts
Nov 24, 2009 | Vacuums
My dyson animal is hard to push on carpet - the beater bar is still operational. When I turn off the beater bar and run the vacuum on hardwood the beater bar stops moving, but it still ''rolls'' on the...
If suction is not what it was, check all of your hoses and connections for vacuum leaks. And the beater roll should always be turning - check out the belt for slippage.
Sep 20, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
130 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
