Question about Coby Televison & Video
Need adator for DTV converter box.
I have the Coby TF-TV705 LCD color TV/Monitor and purchased a digital tv coveter box but I am unable to connect it because I don't have any way of connecting the TV antenna to the box.
    President:
  • 2,992 Answers
The converter box needs an antenna, but not the one built into the TV. In fact, you should get an antenna designed for the new DTV broadcasts to get the best reception. There are a number of styles and they start at under $10.
To connect the converter box to the TV, you have a couple of options. You can use the channel 3 or 4 output from the box and connect the cable to the TV external antenna jack with the appropriate adapter. Or, since this TV also works as a monitor, you could use the converter box video and audio outputs instead. If the TV has a single A/V input jack instead of separate audio and video jacks (the usual case), Radio Shack and other vendors sell the adapter cable you'll need. One might have been supplied with the TV.
Posted on Feb 11, 2009
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
How do I change from Digital to Analog TV?
source mode,(button on tv usually next to menu) tv menu ( usually first page at top of screen), . or tv/dtv on remote ( some times just say DVT on it but you press it twice to go analog ) it all depends on your tv, also depends if the system on the tv has been updated some tv's when the change over happens, remove analog settings so there is no analog on the tv just digital. you can buy an analog box that will fit to the av socket or just connect a old video to the scart socket and get analog that way.
Sep 14, 2013 | Coby TF-TV3217 32 in. LCD TV
I am unable to get any channels on 2 portable tv,s in the bedrooms since the digital switchover are my tv,s now defunct and do i need to buy new ones ??
The 2 portable tvs,dose it have a big bulky back?Yes,than these 2 tvs are analoge tvs.U still can use them though for DTV free air channels broadcasting by running it throught a box called a Ditgital Coverter Box.These Digital Coveter boxes u still can buy them on websites like Amazon.com,Ebay.com to used for analoge tvs wanted to pickup free air DTV channels broadcasting.
Sep 03, 2011 | Toshiba 19AV600U TV
HD TV?
No,it a tube tv,it analog tv.It well reqiure a DTV converter box to get DTV signal.Only LCD screen tv have digital tuner,to get the DTV with out the digital converter box.
Feb 10, 2010 | Daewoo Televison & Video
Does this tv have a digital tuner or will I need a converter box?
Coby tf-dvd1540 tv
No ATSC tuner in this TV. You will need a converter.
Product Features
  • 15-inch flat-panel TFT LCD TV with built-in side-loading DVD player
  • Standard 4:3 aspect ratio, native 1,024 x 768 resolution
  • Plays DVD, CD and recordable MP3 music CD-R/CD-RW
  • Built-in NTSC TV tuner lets you switch between DVD and terrestrial broadcast viewing
  • Stereo speakers with 3 watts per channel; includes full-function remote control; onscreen display simplifies setup and operation
Technical Details
  • Brand Name: Coby
  • Model: TFDVD-1540
  • Display Technology: TFT active matrix
  • Display Size: 15 inches
  • Image Aspect Ratio: 4:3
  • is_hdtv_compatible: N
  • speakers_included_description: 2 speakers
May 13, 2009 | Coby TF-DVD1540 15 in. TV/DVD Combo
Does a CT-27614A need a digital converter for antenna?
According to http://www.dtv.gov/consumercorner.html#faq9
I hope this soultion is helpful.
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Panasonic Televison & Video
Televison & Video Logo
280 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
