power button flashes 6 times then 1 quick flash does anybody know what this code is? tv does not turn on only has sound for a second then flashes code.power button flashes 6 times then 1 quick flash does anybody know what this code is? tv does not turn on only has sound for a second then flashes code.
AnonymousMay 04, 2009
No picture when powered, sound for 15 sec. and then to flashes 6 with a quick flash ending the sequence...No picture when powered, sound for 15 sec. and then to flashes 6 with a quick flash ending the sequence...
You can't post conmments that contain an email address.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Two problems: first, tv turns off for about 10 seconds after being on awhile, then turns back on. 2nd, picture will sometimes go black horizontally displaying only half of the upper screen. This will go on for about an hour off and on.
I do recommend checking the power coming out of the power supply to make sure it is not to high. It is common for these units to have faulty internal capacitors in the power supply. It may be shorting out other components. You can buy a capacitor tester or use an ohmmeter.
I have the exact same problem! I have it hooked up to a power strip now to unplug it by flicking of the power strip and waiting for the red light to go out then I turn it back on while Channeling up 10 X's and then down and up until it comes on. I listen to the sound of the switch which it comes on. I turn it off if it is faint and then back on and channel up. Crazy process but it's been working. It takes about 10 minutes everytime to get the TV on until I get a tech to come out and look at it. The capacitor keeps a charge which is why the light is flashing with a code for 60 seconds./JJ
6 blinks means general I2C error and 8 blinks means 3D comb filter I2C error. you will need a new signal board for your set, or possibly have yours remanufactured which may be considerably cheaper than a new board. If you need more info please repond to this same post and let me know.
check the wires inside at the left lower region as you are looking at the rear. There are several circuit boards there that tend to loosen when moved. The cables are really ribbons like those used in computers. I'd lioke to be more specific however I'm not entirely familiar with this model, just rear projection tvs in general.
