Question about Whirlpool LER5636P Electric Dryer
DRYER RUNS TEMPERARILY WITH WHINNING NOISE THEN SHUTS OFF.
I CAN PUSH START THE DRUM AND IT WILL RUN FOR A FEW MINUTES THEN SHUT DOWN.SOMETIMES A FAINT BURNT RUBBER SMELL BUT NOT ALL THE TIME.
  • 547 Answers
Take off front of the dryer the drum will fall out clean drum and replace belt
Posted on Feb 11, 2009
Dryer rattles
sometimes a blower wheel will become worn out on the motor shaft and just spin freely cusing very noisy and no air movement causing overheating
Nov 23, 2013 | Dryers
I push button to turn on it starts to turn that fan with a loud noise then sometimes starts then shuts off after a few minutes..please help me..its a roper 5 cycle electric
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 14, 2011 | Roper REX4634KQ Electric Dryer
Have a 90 series kenmore dryer, won't always run. replaced the motor about 6 months ago, and now it will sometimes run, sometimes not. It gets hot, and will run for a bit then shut down, then start up...
If the timer is not advancing but is ticking that could be the problem. A dryer achieves a set temperature and stays there for a certain amount of time during a cycle. If the time never changes it may just keep heating up until the heat sensor shuts it down. If it is starting and shutting down its likely still related to the heat sensor.
Dec 07, 2009 | Dryers
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Dryer only works for about 20 minutes, buzzes then stops.
the dryer is over heating up due to a blocked steam pipe , fluff build up inside the dryer. I have a dryer that id the exact same thing , found out it covered in fluff though out the whole dryer , motor and element ..
Jun 21, 2008 | Dryers
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Oct 15, 2007 | Kenmore 62602 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
64 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
