Question about Rinnai EnergySaver 556 Air Conditioner
Rinnai 556 Heater
When you put it on, the lights flash and it has not sound like its going to fire up. Is there a reset button like one another one I have but a different model. Just an fyi (Yes there is gas).
  • Cary Crook May 11, 2010
    In the manual it will give you a procedure to recall the error codes stored in the memory. Get a pencil in hand and be prepared to write them down. If will help if a friend writes them down. I think you have to press a few buttons together to get the error codes.
Call Rinnai. I have replaced about 15 control boards that have an issue rating with the capacitor microfahred rating. There is no recall, but if you at least let them run your EXACT MODEL AND SERIAL number you may be pleasantly suprised that they send someone out to replace the board.
If you have a dual port digital manometer and are handy, you may be able to install a new board. You MUST reset the high and low fire rate with the new board. Hope this helps
Al
Posted on Sep 25, 2009
  • 53 Answers
No reset button
Posted on Jul 17, 2009
Rinnai 556 WT gas space heater flashing PF
most modern gas heaters use a code system to tell the operator what the problem is. look for a pattern in the flashing, and then compare that pattern to the literature on the inside of the heaters panel. When you have a diagnosis code, you can follow the appropriate course of action.
Nov 20, 2013 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rinnai DV Propain Heater 556F
Sounds like the relay might be going bad and needs to be replaced
Apr 10, 2008 | Rinnai EnergySaver 556 Air Conditioner
Heater shuts off and lights blink
go to rinnai's website and look up the manual for the diagnostic codes. rinnai.us, look under literature/manuals. type in "556". It will tell you how to retreive the error codes.
Oct 17, 2009 | Rinnai EnergySaver 556 Air Conditioner
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
www.rinnai.co.nz
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
Looking for Manuals
Google rinnai 1004 and 556 manuals. I just did and found them
Nov 26, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Ductless heater shutting down
There is a small wiring harness that goes from the main board down to the sparker board at the very bottom of the heater. Disconnect this harness and reconnect making sure all pins and contacts make good connection. If it continues, replace the wire harness. Also make sure the outlet that the heater is plugged into is a grounded outlet. Stray voltage can interrupt the thinking of this unit.
If all connections are good and the unit is grounded, you are probably looking at replacing the sparker board. I do have these parts and would be more than happy to send them to you for a donation.
Jan 17, 2008 | Rinnai EnergySaver 556 Air Conditioner
Rinnai EnergySaver 556F Heater flashes
I'm picking up a faint propane scent when the heater is completely turned off. When I turn the heater on it lights fine so I don't suspect it's the pilot light. Is this an issue with the installation of the fuel line, or could it still be the pilot? Any ideas on troubleshooting the source?
Nov 10, 2007 | Rinnai EnergySaver 556 Air Conditioner
Rinnai EnergySaver 556 Air Conditioner Logo
518 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
