Question about Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 all in one
I put in the new ink cartridges and now my printer will not print and the paper will not even go through. I have disconnected the printer completely and reconnected it back up but I still have nothing. It was working fine until I replaced the new ink cartridges.
  • Anonymous Feb 17, 2009
    the printer was working fine until i ran out of black ink and then i took it and got it refilled and now the black will not print
  • Thomas F. Schneider May 11, 2010
    DId it originally give you a message about low ink or replacing it? Is it giving you any message now?
    http://support.lexmark.com/perl/support/...
Was it a genuine lexmark ink? if not then that is the main reason why it not working
Posted on Mar 02, 2009
My printer light is flashing and I am unable to print
Could be several options
First shut off and disconnect printer from pc and reboot without printer hooked up
once reboot hook it back up and turn on to see if windows found new hardware.check paper and ink
All else fails re-load printer driver
Jun 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
Ink cartridges are full. paper moving. Not printing. no ink on papaer.
printer in ready, but lexmark all in one center's main page did not icon and i can not printer or change color
Apr 17, 2010 | Lexmark X1240 All-In-One InkJet Printer
Printer do not recognise color catrige
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 13, 2009 | Lexmark X1240 All-In-One InkJet Printer
Printer wont print, but it is going through the motions.
If ink cartridges are new, perform print head or maintenance cleaning at least 3x consecutively.
Nov 24, 2008 | Lexmark X1240 All-In-One InkJet Printer
Printer doesn't print even with new ink cartridges.
turn the printer i turned on and Press the cleaning button ,. Cleaning takes about two minutes, the printer makes some noise when it finishes you run a nozzle check for print quality and reset the cleaning cycle.
load paper . go to the printer menu as follows: click Control Panel, and then double-click Printers. Select the Epson printer if have more than one printer is installed. Click File, click Properties, click the Utility tab, then click the Nozzle Check icon.
The printer will print a Nozzle Check pattern in black, and in cyan, magenta, and yellow. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If any dots are missing, clean the head again.
If your software is different, and does not have these options, you can do it this way:
1. Same as above.
2. Same as above.
Turn off printer and computer. Disconnect interface cable from printer. Load paper. Hold down the load/eject button and press the power button to turn on the printer. Release both buttons.
3 Same as above.
4 Turn off printer and reconnect the interface
May 17, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x1240 will not print
did you tried to set the properties to mono ?
Apr 12, 2008 | Lexmark X1240 All-In-One InkJet Printer
All in one printer does not scan or copy
If the Ink Status is showing a ? symbol after you have replaced the tanks, you just need to tell the printer that you replaced tanks ,
To do that , open your lexmark solution centre from the Lexmark start menu group.
Click Maintenence
Click Install New Print Cartridge
Jan 18, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
