Question about Speed Queen AWS52NW Top Load Washer
Water running out from under drum - speed queen washer
I have a speed queen "marathon" heavy duty washer that's at least 10 years old. I cannot locate a serial # or a model #. But, I do have an owner's manual that indicates it's one of the following models: NA8531, NA6531, NA6530, NA5531, NA5530, NA8331, NA6331, NA5331, or NA5330. I took the front panel off to try to see where the leak is. It appears to be leaking in the middle, from under the basket/agitator.
I am pretty handy, and I'm considering attempting to fix it myself. What do you think I need to do? What parts will I need. About what do the parts cost? Where do I get parts? Any help is appreciated. Thanks!
  • 1294 Answers
SOURCE: I am looking for a model number on a Speed Queen Marathon washer
  • Behind the door
  • Behind or on top of the control panel
  • On the side of the unit near the front
You will rate me pl....................
Posted on Mar 06, 2009
mhamlin63
  • 138 Answers
SOURCE: What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
Posted on Jun 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a KENMORE 90 Series Heavy Duty Super
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: washer stoppped in the middle of the cycle.
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: Spots on white clothes
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Speed queen Marathon top loading washer- Water leaks into drum when not in use??? Shut off valves in the basement.
The problem is the water inlet valve has failed. There is a video on checking this at www.appliancehelponline.com/servicemanual.html it's a different model but the testing procedure will be the same.
Mar 28, 2010 | Speed Queen AWS52NW Top Load Washer
Motor rund but drum dont spinon speed queen heavy duty washer
Fluid Drive clutch greasy or worn,
Pump blocked or drive belt too loose
Feb 23, 2010 | Speed Queen AWS75NW Top Load Washer
Vibration
With the age of the machine, although Speed Queen's are built like a tank, the suspension systems are one of the most worked systems on a clothes washer,so, that being said, I would check all related parts of the suspension system, springs,pivot,etc,.these parts do get tired, think of the amount of loads of clothes that you have run through the washer over those 15 years.
Good Luck !
Feb 14, 2010 | Washing Machines
Queen marathon 20 years old does not pump the
If the motor is running then the water pump or the clutch to it has failed. If the motor is not running, the motor has failed. Both fixes are probably too expensive for a 20 year old machine. Unless you are very handy and resourceful it may be time for a new machine.
Jul 11, 2009 | Washing Machines
Jun 29, 2009 | Speed Queen AWS52NW Top Load Washer
  • Behind the door
Mar 06, 2009 | Washing Machines
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Marathon Compucare Dryer
Could be a touchpad problem
Dec 09, 2017 | Dryers
Speed Queen AWS52NW Top Load Washer Logo
106 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
