Question about Canon XL1S Mini DV Digital Camcorder
What setting do i use to run my cordles mic in to audio 1
I have a canon xl1 and , asomson uhf series one micrro diversity receiver and pluged it into audio 1 but when i record it is still getting sound from mic on camara , then i swich ti audio setting and i get no sound , what are the right settings
  • 48 Answers
Without more clarification I am assuming that you have the onboard mic plugged in normally & I don't know where the RF mic is connected.
First thing is that we know that you get sound from the shotgun mic in ch. 1. If you do not plan on using the onboard shotgun, then the fix is easy! Since it has been confirmed that ch. 1 works, just disconnect your shotgun & plug in the RF receiver to that, check your levels, and shoot away.
If you are still wanting to use that shotgun along with the RF, then I suggest that you re-read pages 51 - 54 of the instruction manual. You can find where to jack in, how to set, and change audio levels on these pages. Good Luck!
Posted on Jun 17, 2009
Will transmit but will not receive
I have programmed hundreds of these. The radio may be receiving, but the speaker may be muted. If using a hand mic, have the mic "off hook" or ungrounded and try again. Does the front light flash while the radio is receiving? This indicates the radio is "hearing", just not passing the audio to the speaker. Is there something plugged into the audio jack in the back? Let me know. In 20-30 minutes most shops familiar with Vertex will know exactly what is happening.
Oct 01, 2015 | Vertex Standard VX-2100-G7-45-PKG-1 UHF...
Intermittent LOUD shorting sound
I would prefer to hear it to be sure which one it is, but the four biggest causes of noise in a wireless system are: 1) Something hitting the mic (check to make sure the mic is free of clothing, other people, faces, etc.) 2) If the mic is a lavalier or in some way has a cable that plugs into the transmitter, something pulling on it could create a loud noise. Check to make sure it's in snug. 3) RF Interference with another mic or some other interference source. Try changing the frequency. 4) Something blocking the signal between the transmitter antenna and the receiver antenna. This is most likely to happen with a lavalier in someone's pocket or under clothing, and/or if the transmitter is far away from the receiver. The SLX series is okay for what it is, but part of why it's on the cheaper side is because of its limited distance. Unfortunately the only ways to alleviate this are to a) Reduce the distance, b) get a stronger wireless system, c) move the transmitter somewhere that the antenna is free, and d) invest in True Diversity antennae for the receiver.
Sep 23, 2013 | Shure SLX4 Wireless Receiver with Antennas...
How to connect the canon ma-200 to the canon xl1
You can mount the MA 200 shoulder pad to the XL1 and plug the RCA connector and the mini plug into the port located on the back of camcorder, first open the door. Next, on the side panel where the audio controls are select AUDIO 1. Now assemble a mic using an XLR Cable. Then plug it into the AUDIO 1 port located on the MA 200 Shoulder pad and conduct test. if your using just one mic test the right side, take notice of the gauges located under the handle. the levels should be jumping like crazy. Now remove the XLR cable from the right side and test the left side making your desired audio levels. Now that should work with out question. If not just email me and ill refer you to the YOUTUBE VIDEO. Email me at: Peace, Enjoy your video sound.
May 27, 2012 | Canon MA-200 Microphone for XL1, XL1S
XL1s and 4 channel audio
Unfortunately, Premiere Pro CS3 can only handle two channels of audio at a time when capturing. You could try capturing with Scenalyzer or another program that can handle four channels simultaneously.
Hope this helps!
Nov 06, 2008 | Canon XL1S Mini DV Digital Camcorder
Shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Oct 17, 2008 | Dual Pro2- WM795V Channel VHF Wireless...
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • +48 OFF
  • INPUT 2 -
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Canon XL1S Mini DV Digital Camcorder Logo
79 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
