Question about Brother Office Equipment & Supplies
Can the brother mfc 7820 be used on a wireless network
I didn't buy the ''n'' model. Can I still get it to work
  • 3 more comments
  • hhanssprint Feb 11, 2009
    Hi
    That is correct, my printer does not have an ethernet port. I have a desk top computer with a router, and a laptop I use wirelessly. the printer is connected to the desktop by a usb. I've tried adding the printer, sharing the printer and the network searches and can find no printer
    I am already stuck on step one. I'm running xp, but when I go to "my computer" I don't see properties, unless you mean for the C drive or other drives. How do I rename computers. I should also tell you that my desktop is 32bit and my laptop is 64. should this make a difference?
    Ok I made a mistake. I RIGHT clicked and found properties. Only one computer is there
    I made a mistake. Sorry. my printer is mfc 7420. I didn't purchase the model that has the N at the end indicating network I think. I have vista 64 and windows xp 32
  • mgkyle May 11, 2010
    If you want to be able to use this printer via a wireless network from another computer, you will probably have to connect the printer to 1) a desktop computer and share the printer, 2) a wireless print server, or 3) a network print server which you would connect to an ethernet port on your router.
    Just to verify, this printer has no ethernet port, is that correct?
So, you want to share a printer from a desktop computer to wireless clients. I am assuming you are using Windows XP on the desktop computer. If that is not the case, let me know if you cannot figure out corresponding steps for your operating system.
With Windows sharing, the first thing is to make certain you have all computers in the same workgroup and assign them different manes. To do this:
1. RIGHT click on 'My Computer' (either on the desktop if it is there or in the start menu).
2. Select 'Properties.'
3. Click on 'Computer Name.'
4. Click 'Change.'
5. In computer name, type a name for each computer (perhaps 'desktop' and xx-laptop, replacing xx with your initials); it doesn't matter what you put here, they just cannot be the same on any two computers.
6. Make certain the workgroup radio button is selected and type a workgroup name. The workgroup name must be the same on all computers to make this work easily. Anything will do. Common chioces are your last name, 'workgroup', and 'mshome'.
7. Click 'ok' and 'ok' and allow your computer to reboot if you changed anything. Remember to do this on the desktop and all the computers you are going to use the printer with, too.
Now, we need to set up sharing on the desktop. I am assuming that the printer works from the desktop without problem. You have probably already done the following, but check it to be sure:
1. Open the printer dialog (Start-->Printers and Faxes OR if that isn't there Start-->Control Panel-->Printers and Faxes).
2. Right click the printer you want to share.
3. Select 'Sharing'.
4. Assign a share name.
Finally, on the laptop you need to set up the printer:
1. Go to 'My Network Places' (one way is by opening 'My Computer' and clicking 'My Netowrk Places' at the left.
2. Select the name you gave to the desktop (if this is not here, we will need to troubleshoot other parts of your network).
3. The shared printer should show up.
4. RIGHT click on the printer and select 'Install/Connect'.
5. If it asks for a driver, provide the driver file.
6. Print something ;)
Posted on Feb 11, 2009
  • 1 more comment
  • mgkyle Feb 11, 2009
    Try following the steps again now that you have figured out how to get the the System Properties menu. You will need to set a computer names and make certain that the workgroup name is the same on all of your computers.
    If you have Vista x64 or Windows XP x64 you will need to get the driver for that computer for when it asks. I went to Brother's web site and looked for the driver for the 'N' version they have a 64-bit driver. They do not seem to think they manufactured a MFC-7820 (without the N). http://welcome.solutions.brother.com/BSC...
    So the drivers would be athttp://welcome.solutions.brother.com/BSC...{2C7B4D65-D5B3-47BF-958E-322BE5EFDCA8}&NRORIGINALURL=%2fbsc%2fpublic%2fus%2fus%2fen%2fdlf%2fdownload_top.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dmfc7420_all&NRCACHEHINT=NoModifyGuest&prod=mfc7420_all®=us&c=us&lang=en
    Nothing else changes. You just need to start at the beginning step by step and you should have it all working fine.
I have a Brother MFC-7340. It says that it can print wirelessly, but I don't know how to make it discoverable, if that's possible. It also doesn't have an ethernet port, so I can't connect to network....
this is the support site for that printer http://www.brother-usa.com/support/default.aspx?PGID=5&R3ModelID=mfc7340 if you look at the quick start manual here http://www.brother-usa.com/support/default.aspx?PGID=5&R3ModelID=mfc7340 to have the network adapter the model number needs to have an "N" as part of the model 7340N
otherwise you will have to use USB connected to a PC - and the PC on to share on the network
Aug 10, 2010 | Brother MFC-7340 All-In-One Laser Printer
MFC 465cn, how do i access it wireless?
You must first set it up, and then connect to it as a "Networked Printer" and then hook up;
All Drivers must be installed.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Set it up as above tutorial.
Apr 04, 2010 | Brother Multi-Function Center MFC-240C...
Need the printer MFC 7820 N installed on my computer
Hi and welcome to Fixya!
download the driver and install it ...
http://solutions.brother.com/mfc7820n_all/en_us/
Thanks for using FixYa!
Jul 17, 2009 | Brother MFC-7820N Printer
My printer folds the paper in the back accordian
check the drum unit and toner unit, also check on all rolls inside the printer.
if still not working you can send it to me to fix it for you.
Jul 13, 2009 | Brother MFC 7420 All-In-One Laser Printer
I have the Brother MFC-7820, I just purchase a laptop with a Windows Vista. I am unable to use the printer. What do I do?
23/Feb/ 07: Updated the Brother original driver(Full Driver & Software Package) for the following products to fix a driver installation problem: FAX-2820, FAX-2920, DCP-7020, DCP-8060, DCP-8065DN, MFC-7220, MFC-7225N, MFC-7420 ,MFC-7820N, MFC-8460N, MFC-8660DN, MFC-8860DN, MFC-8870DW, MFC-9420C
And here is the link of the updated full driver and software package. After you download this, you should be able to run the MFC 7820 with your new laptop=)
Nov 25, 2008 | Brother Office Equipment & Supplies
Brother 7820 Network setup problem
Spoke to soon. the supplied disc failed working the next day.
I think your problem is your firewall!.
Disable the firewall and see if you can print / start it scanning from the brother control center.
If so you know its a firwall prob.
I gave up on trying to configure Norton to recognise it.
I uninstalled Norton Internet Security and then reinstalled it after making sure the printer was printing and the scanning etc could be started. Working fine so far ( a few hours). I am reasonably confident that this will be ok. If the machine has already communicated with the printer then Norton recognises this and allows it. If however the first time you try is after installing Norton it will block it!
DSKDSK
Mar 29, 2008 | Brother MFC-7820N Laser Printer
Printer goes offline
Set IP of printer manually and make sure AutoIP is off. Printout user settings to ensure.
Dec 11, 2007 | Brother MFC-7820N Printer
Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at WardLF357@aol.com:
Oct 17, 2007 | Brother MFC-7820N Laser Printer
197 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
