Question about Nikon Coolpix 3200 Digital Camera
Coolpix 3200 interior possitive (+) battery post disconnected...
On coolpix3200, interior metal connectors on bottom of battery chamber complete electrical connection with metal posts on top cover. The left side bottom contact for positive battery side came loose and need to know how to replace or restore properly, if possible, or do I need to return to dealer or repair shop.
  • 423 Answers
There is a way to fix it, but it involves soldering. You can solder that piece back into place. It should only take you about a minute to do the job.
Your going to need a slim soldering iron (in order to reach down in the battery compartment), a piece of solder, and maybe a third hand to hold the connector in place. It should only take a drop or two of solder to do the trick.
If your not comfortable with that, then you need to take it to a shop. Hope this helps you.
Rob
Posted on Mar 10, 2009
Nikon Coolpix 3200 won't turn on even when connected to computer via the usb cable
Disconnect the camera from the computer and put in a new set of batteries. Connecting the camera to a computer simply drains the batteries faster.
Feb 21, 2011 | Nikon Coolpix 3200 Digital Camera
How to correctly install batteries in ultra model 1000ap?
Place your two new type CB1270 batteries on their sides, one on top of the other in front of you with the battery connectors closest to you and with the battery connectors to your left. Connect the short (2 inch) jumper cable between the two center battery posts (1 red/1 black). Slide the battery stack into the chassis with the battery posts to your left as you face the front of the UPS and be careful that the battery posts do not touch the metal chassis. When the batteries have been slid completely into the chassis, connect the heavy red wire from the circuit board to the red battery connector at the bottom of the battery stack and the heavy black wire from the circuit board to the top black battery connector. If you have doubts about your wiring, use a DC voltmeter set to the 50v range and touch the red probe to the red battery post at the bottom of the battery stack while touching the black probe to the black battery post at the top of the stack. The reading on your meter should be somewhere between +24 and +26v depending on the charge level of your batteries.
Nov 04, 2010 | Ultra (ULT31502) UPS System
Location of fuel filter 1995 Nissan Maxima
  1. This is if it is an internal filter, if it is not you still have to pull the whole bottom of the back seat out and look for the inspection plate.
  2. Relieve the fuel system pressure by first removing the fuel pump fuse. Then, start the engine and allow it to run until it stalls. Crank the engine for 2 to 3 seconds to release the pressure Turn the ignition off.
  3. Step 2 Disconnect the negative battery cable. Remove the rear seat bottom and the inspection hole cover. Disconnect the electrical and quick connectors and remove the six screws. Remove the fuel level sensor unit and the fuel pump assembly. Then, take out the flange and snap fit portion of the fuel pump.
  4. Step 3 Remove the fuel tank temperature sensor harness, the fuel level sensor flange, and the fuel pump connector. Disconnect the quick connectors from the fuel level sensor, and remove the fuel level sensor from the chamber. Take out the fuel filter.
  5. Step 4 Put the new fuel filter in the chamber, followed by the fuel level sensor. Attach the quick connectors to the fuel sensor. Connect the fuel pump connector and put the fuel level sensor flange and fuel tank temperature sensor harness back.
  6. Step 5 Place the fuel pump assembly inside the tank. Replace the screws and electrical connectors. Reattach the quick connectors. Reconnect the negative battery cable.
  7. Step 6 Start your car and check for leaks, and make repairs if necessary. When repairs are complete, replace the inspection hole cover and the rear seat bottom.
Feb 03, 2010 | 1995 Nissan Maxima
Battery cover broken
If you want to do the replacement yourself, you may order the part from here.
Jun 22, 2009 | Nikon Coolpix 3200 Digital Camera
Broken exterior door handle,passenger sider ,sliding
Got this idea from mpvclub.com: Get some stainless or aluminum sheet metal screws, drill pilot hole into the handle and into the receiving part behind, then screw in the screw. Do on both sides of handle (get appropriate length screw.) When done, get some putty or hardener to fill in the screw slot, let dry, then sand smooth, then paint with body color. Result is great and inexpensive.
Jan 26, 2009 | 2004 Mazda MPV
System error showing up on Nikon coolpix 3200
A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
1. Use the memory card that originally came with the camera (or a Nikon approved card)
2. Remove and replace the battery
If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
Jun 13, 2008 | Nikon Coolpix 3200 Digital Camera
Coolpix3200
Check by plugging it into the other USB Port, sometimes a port refresh helps, Some times if you start up your mac with the camera plugged in it only thinks it has a drive there...swap to the other drive and wait to see if it is recognised, you can also open drive utility and look for it there as a Plug in Drive... this may help as it may show up there unmounted, if so then click the Mount Button. ...C
May 09, 2008 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Oct 15, 2007 | Nikon Coolpix 3200 Digital Camera
Coolpix 2200/3200 Battery Compatibility
The Coolpix 2200 / 3200 camera is designed to use 2 (two) AA type batteries. Due to Nikon’s advanced power management technology, two standard AA Alkaline batteries can provide more than 100 photographs. For better performance, please consider using Nikon EN-MH1 rechargeable batteries. These are available as an optional accessory at Nikon dealers and at The Nikon Mall Recently a new type of battery, the CR-V3, has been released to the market from several battery venders. The CR-V3 is similar in shape to two connected AA batteries and easily fits in your Coolpix camera compartment. Nikon has confirmed compatibility only with the following battery brands. Please use one of the following brands when using CR-V3 type batteries. Duracell Sanyo Panasonic Due to it’s unique design the Eveready Energizer® brand CR-V3 battery may not be compatible with the Coolpix 2200/3200 camera.
Aug 30, 2005 | Nikon Coolpix 2200 Digital Camera
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 3200 Digital Camera Logo
51 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
