Question about Jenn-Air JCD2389G Side by Side Refrigerator
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way raphael@raphaelbachrach.com I have a Jenn Air side by side about 10 years old. The refrigerator is barely cold on the coldest setting. The freezer works fine.
    Genius:
  • 2,920 Answers
You may be low on freon or have a freon leak...youll need to call a serice repairman to come check it but it sounds like its low on freon
Posted on Feb 10, 2009
I have a jenn-air jcd2389ges that is not getting cold.it runs and works but is not getting cold ..
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
May 20, 2010 | Jenn-Air JCD2389G Side by Side...
I have a Jenn Air JS48FSDBFA. The freezer works fine but the fridge wont get below 46-47 degrees. What could it be.
May 21, 2010 | Jenn-Air JCB2280HES Side by Side...
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way raphael@raphaelbachrach.com I purchased a Kenmore fridge in Aug. 2005 (no freezer - fridge only). During a couple weeks...
I see several things wrong here. There is a vent or duct that allows some cold air from the freezer to the refrigerator. This vent may be blocked. Look to see if anything is in the way. Next, you may want to stay on Sears to fix this problem. Call them and ask for a time to be there. Then call daily after that and eventually they will respond. The squeaky wheel gets the oil! The problem may be in the compressor or evaporator. Hopefully, this is still under warranty. Let me know how you do.
Feb 14, 2009 | Freezers
assuming you have had the appliance unplugged for a while, plug back in and it may well work ok. if so, get back to me and i'll take it further
Aug 31, 2008 | Refrigerators
Jenn-Air Refrigerator Not Cooling
As others have noted, the solution is counter-intuitive but easy. The refrigerator keeps cold on this model by cold air coming over from the freezer side. So most likely it is ice blocking the freezer coils or the fan that moves the air. So turn off the freezer and defrost it. You will need to remove the big white plate on the back of the freezer (on the inside) to most effectively get the ice to melt. You can use a hair dryer for this, or just leave the freezer sitting with the door open for several hours.
Jul 09, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerator not getting cold - freezer still pretty cold - perhaps not all the way raphael@raphaelbachrach.com refrigerator not getting cold - freezer side is working
Sounds like a defrost problem or dirty coils under the machine. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 01, 2008 | Maytag MZD2766GES Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
194 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
