Question about Sharp AR-M237 Copier
Adf misfeed ar-m237
Lay paper on adf tray. machine recognizes it. push copy and machine will spit out paper and then says there is a misfeed in copier and adf. i have swapped out the whole feeder and the board that adf plugs into. i would greatly appreciate any help.
Thanks for your time.
Jerry Henry
817-992-8771
  • 1 more comment
  • jerry henry Feb 12, 2009
    i swapped out a.d.f.. same problem
    swapped out a.d.f.. same problem.
  • John Cole
    John Cole May 11, 2010
    Hey Jerry it sounds like it could be a sensor flag issue have you tried a paper path test?
  • Sharp Expert
  • 257 Answers
Try cleaning the pick rollers with alcohol or clean cloth dampened with water.
Posted on Jul 28, 2009
Get a misfeed has occurred but there is no missfeed
Your paper may not be feeding, try your bypass tray. If that works you may need new feed tires for your cassette.
May 23, 2014 | Sharp AR-M237 Copier
Sharp AR-M237 a misfeed has occurred, top feeder. there is no paper have did as the information states and still will not clear.
Is the jam indicated inside the copier or on the document feeder that scans the paper across the glass ?
Mar 19, 2011 | Sharp AR-M237 Copier
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
I have an AR-m237 that tray 1 will not pull paper, tray 2 works fine
is tray 1 recognized if not the little switch on the back of the machine behind tray one in blown, other wise you have to see if the rollers turn
Jul 08, 2010 | Sharp AR-M237 Copier
Copier Sharp AR-M237 a Misfeed Occurred message
First try a different tray to see if it works, if it does than the paper tray you are using may have dirty feed tires or look for something obstructing it.
Mar 24, 2010 | Kyocera CopyStar CS-3060 Black and White...
Sharp AR-M237
please clean the sensor and feed the paper
Mar 17, 2010 | Kyocera CopyStar CS-3060 Black and White...
Paper misfeed indicator light continues to blink even after paper
some machines will want all covers to be opened, then closed, for good reset. if you are having jams in the adf, then open all adf covers, and lift the adf upward, if it allows. also, try turning unit off, then back on. some jams only clear that way.
Apr 02, 2009 | Sharp AL-1641CS Laser Digital Copier
Misfeeds
DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Sep 16, 2007 | Sharp AR-M455N Copier
Sharp AR-M237 Copier Logo
226 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
