Question about NEC VT47 Multimedia Projector
Data Projector projecting upside down
The computer image is okay but the image on the screen is upside down. It is a texas instrument XD510U model.
    Problem Solver:
  • 5 Answers
If you go onto your menu and click on "setup". Press orientation and select the right one for your projector. It allows you to choose whether your projector is on a table top or ceiling mounted etc.
Posted on Feb 19, 2009
Picture is upside down on my mitshbishi dlp projector
In the menu you need to find the reverse image it has four settings
Jul 09, 2014 | Mitsubishi XD510U DLP Projector
Upside down picture on Vivitek D530
Hello
Check the Projection setting on the Installation I menu of the OSD
Feb 11, 2012 | Vivitek D530 Projector
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
Image is upside down on the screen
Alot of projectors (being all projectors that are designed to be hung from a roof) have an image flip function. This is because when you install a projector in a roof you have to flip the projector upside down so the projector doesn't have to be pointed down and doesn't cause any problems with keystoning.
If you have just bought a new projector and installed it in the roof or perhaps bought it second hand and are projecting from the floor (when the previous owner may have had it in the roof), you will need to go through the menu screen until you find this setting. I don't know exactly what Epson call this function but it should be in there somewhere. If you have it on the floor you want image flip off, if you have it in the roof you want vertical image flip on, horizontal image flip is for when your projecting onto a special screen surface from behind the screen.
Mar 24, 2011 | Epson PowerLite 3LCD Projector
We have inherited a Sanyo Pro-X multiverse projector without an instruction manual. The projector was fixed to a ceiling but we would like to use it freestanding. When attempting to use the projector this...
You need to turn off the ceiling mode to get the picture to project correctly. This is in the Settings Menu. See page 37 of the manual which is currently available here: http://cncms.com.au/SANYO-IMs/Commercial-Industrial/plcsw30_im.pdf .
Press Menu. Then use the left/right arrows to move to the icon with the projector and screen shown. (Note: right now this row will be on the bottom of your screen and the icon will be to the left side of the row.) Press the down arrow and move to the Ceiling icon with the R. It should be the seventh icon from the upside down "Up" arrow; it's next to the Capture icon with a camera. (Normally, ceiling icon shows as an upside down R when your image is projected right-side up. There is also a rear-projector icon with a mirror image R when the image is right-side up.) Press Select and then use the arrow keys to choose the On/Off options. You may need to press Select again to save the setting.
I hope this helps.
Oct 11, 2017 | Sanyo PLC-SW30 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Upside down picture how do you invert the images projected
Go to menu and select images and click arrow left or right to invert image position.
Mar 21, 2010 | Eiki LC-XB20 Projector Multimedia...
NEC VT47 Multimedia Projector Logo
1,427 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
