Question about Pentair Challenger High Head 1.5 Hp Pump Up Rated
Pentair legend moves slow.
Hi, my pool sweep has never flowed properly in the pool since pool was built in 2006. when it works it just goes in circles. never picks anything up. I have only seen it go to the shallow end of the pool a hand full of times. Lines are clear pump booster was replaced twice. have no idea whats wrong. pool company will not help
    Problem Solver:
  • 10 Answers
What type of cleaner is it..
Posted on Mar 11, 2009
Sweep hose tangles in wheels
Sweep / Whip hose is too Active...
turn the adjustment screw 'In' to make it a more Lazy action.
Oct 12, 2013 | Pentair White/Gray Legend Platinum...
Tail on pool sweep is not moving
screw on bottom open up it will let water in and tail will wag
Jan 27, 2013 | Pentair White/Gray Legend Platinum...
Pentair legend platinum sweep hose doesn't sweep
open up the screw on the bottom that will let water to the tail
Apr 28, 2012 | Pentair White/Gray Legend Platinum...
The sweep tail doesnt sweep
Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. You might also need to adjust the screw that holds the sweep hose in place. If it is too tight it will not have the slack to move. If it is too loose, it will not have enough tension to move. Try adjusting it and it should have the pool cleaners sweep hose motion.
Mar 14, 2011 | Pentair White/Gray Legend Platinum...
After two years of perfeft performance, the Legend Platinum start to misbehave. Whells runing at 23 to 25 RPM after cleaning the hose filter. Main pool filter runs at 23 psi, booster pump runs and pressur ...
If your RPM is low, you will need to increase pressure to the cleaner. If the sweep hose is laying on the side and not sweeping, you will need to adjust the screw that holds it on to get it to a gentle sweeping motion. It is also possible that you have too much hose weight on the pool cleaners sweep hose. Try removing some of the weight and seeing if that changes.
Sep 14, 2010 | Pentair White/Gray Legend Platinum...
Our Pentair Legend moves to a wall and stay there
Yes place the left jet (it rotataes) to the 11:00 position and the right jet to the 5:00 position and it will run correctly.
The Pool Tech
Jun 28, 2010 | Pentair White/Gray Legend Platinum...
Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Oct 04, 2009 | Pentair White/Gray Legend Platinum...
My Pentair Legend Pool Cleaner is too slow
Here is a link to the factory website where they have technical support for this kind of problem.
Legend Pool Cleaner
Feb 23, 2009 | Pentair White/Gray Legend Platinum...
Pentair Challenger High Head 1.5 Hp Pump Up Rated Logo
154 people viewed this question
Top Pentair Garden Experts
Charles T Nevin
Charles T Nevin
David Burbee
David Burbee
Electro Med Services...
Are you a Pentair Garden Expert? Answer questions, earn points and help others
