Question about GE GBS22HCR Bottom Freezer Refrigerator
GE GBS18HBRAWW / ICE BUILD UP IN DRAIN LINE/TROUGH
REMOVE ICE FROM DRAIN TROUGH UNCLOGGED DRAIN LINE / IN ABOUT 1 MONTH DRAIN IS ICING UP AGAIN / IS THERE A KIT THAT WILL RESOLVE THIS PROBLEM FOR BOTTOM MT. G E REFRIG.
  • READYTOPUNT Mar 06, 2009
    I have experienced the same problem with my G.E. fridge about 3 years old. Fridge on top freezer on the bottom. I have changed out the defrost timer as well as the defrost thermostat. The heating element is good and the drain is clear. Fridge works for about 2 weeks and then you hear the fan hitting the ice that has built up again around the drain area. So the defrost cycle seems to be working but ice still some how keeps building back up around the drain area again and you have to manually go in and defrost the ice build up. Any suggestions out there other than junking the G.E. heap?
  • 2,418 Answers
Check for a blockage around the through area from the freezer to the refrig. or something such as a jug of milk that you keep in the same loacation time after time. if this jug or what ever stays in this area that can cause a cold spot and keep that area from getting warm enough to let ice thaw.
Posted on Mar 10, 2009
Ice Build up on freezer floor then leaks out the front on to the floor. Drain tube is not plugged. The ice builds up in the drain trough then over flows on to the floor of freezer.
Not usually, will have to thaw, then run pan of hot water through drai. Can pull lower vent cover off to make sure it runs into drain pan under fridge. Drain may look clean but tube may not be. Can take wire from hanger to clear as well.
Sep 29, 2015 | Refrigerators
Water leaking from bottom front, ice in bottom of freezer
Your drain line form the evaporator is clogged. Locate the drain under the back and use a wet/dry vacuum to unclogged drain. The drain line can be also blocked by excessive ice buildup from incomplete defrosting. Remove frozen foods and open door to freezer section and remove power and manually defrost unit. Once ice is stopped melting try vacuuming the drain line again. Sometime drain line gets clogged with debris such as garden peas, corn, wrapping and the like. Once drain line is cleared the water and ice on the freezer bottom should stop forming.
Hope this helps
Dec 12, 2014 | Refrigerators
Why is my GE TPS24 drain freezing
It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube. Small particles of food can build up in the drain. Ice forms around the particles and blocks the drain. Sometimes the insulation gets saturated with water and the drain will continue to freeze up in about a month or so. If this is the case there isn't much that can be done except replace the refroigerator
Aug 15, 2014 | Refrigerators
Inside bottom of freezer every few days theres about a 1/8 of an inch of ice. Can you help me. I have cleaned out the freezer several times but cannot find the origin of the water. Thank you
The water is from the defrost cycle thawing the evaporator coil.
The defrost drain line in the freezer is frozen over with ice and the defrost water is not draining.
Turn off the power and remove the rear freezer panel and the freezer bottom panel.
Use a hair dryer to defrost the ice at the drain hole in the center of the drain trough underneath the coil in the back of the freezer.
This will take some time to do because the process will be slow.
Jul 31, 2011 | GE GTS12BBPR Top Freezer Refrigerator
Freezer is icing up and we are getting water in side the frig, however frig is still cold and operating.
sounds like you have a drain problem, the drain line from inside the freezer is probably clogged. you can remove the back panel in the freezer. The evaporator fan, evaporator, ad heater should now be exposed. Under the evaporator there will be a thin metal sheet with a hole in the middle. you can take a screw driver or something thin and sharp and chip away at the ice in the drain line. Boil or microwave some water until hot and pour it into the drain line. You can take a wire hanger and stick it in the drain line also. when it is unclogged you will hear the water hitting the drain pan under the fridge.
Feb 03, 2011 | Refrigerators
I have a GE profile side by side, model #TFH24PRX, every other day or so there is water of the floor at the front. Not sure what the problem is. Please help
If you look in your freezer down at the floor you'll probably see a sheet of ice that has built up over time. This is caused from the drain line located underneath the evaporator coil which is behind the freezer wall to clog up, usually with ice. Remove the ice in the floor, then remove the bin. Once that is done look at the back wall the n follow it down. Normally you'll see a trough of sorts, but in some models you may have to remove the freezer wall to get to it. Once you have located the trough, clear the ice from it, and located the drain hole. To clear the ice from the drain itself you can use hot water, a hair dryer, or a screw driver and tap it out. If you use a screw driver be careful not to punch a hole in the line. Once water can freely be poured down the drain, you problem is resolved.
Nov 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
PDS18SBMRBS model GE Profile fridge. The fan
the heater unit might be weak and usualy it is a hlogen light that need to be replace , so the defrost will be better
Jan 01, 2010 | GE Refrigerators
Refrigerator is leaking water inside and down under the vegetable compartment. Every two weeks the water pools up.
You have an icing issue whereby the drain tube is getting blocked with ice and so when it goes into auto defrost the water can't get down the drain tube so it runs down the back wall of the fridge and lays under the crisper drawers. You need to check out the tube to see if it is ice or sometimes a bit of debris from the freezer can get stuck in the drain cup/tube. If it is an icing up problem check the defrost timer, the defrost heater and the defrost thermostat. Hope this will help.
Nov 19, 2009 | GE Refrigerators
GE with top freezer has water accumulating in bottom of frig under the crisper drawers.
Remove the food from the freezer , then remove the icemaker , if it has one ( 2 screws ) . Remove the rear freezer panel . Useing a hair dryer , start in the middle of the drain trough , and defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water will go thru . Use a piece of tubing inserted into the hole , and blow thru , to remove any debris accumulated in drain line .Remove any excess ice from trough . Reassemble freezer .
Aug 27, 2009 | GE Refrigerators
How do you unstop the drain line
Remove the freezer back wall and lower panel. Remove the visible ice. Use a hair dryer to defrost the drain hole in the rear trough.
Mar 13, 2009 | GE Refrigerators
GE GBS22HCR Bottom Freezer Refrigerator Logo
752 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
