Question about Philips Magnavox 42MF521D/37 Television
Not getting full pic on certain channels
We just had cable put in and now we do not get the full pic on certain channels, we are getting static lines on the top and part of the pic on top is blacked out.... We called time warner they came out and claim it is not their signal.... we never had this problem before we had the cable put it in.
    Problem Solver:
  • 5 Answers
I've seen this problem before. Try to adjust the horizontal settings in the tv. you should be able to adjust the picture up just a bit and it will get rid of the lines. also if you are hooked up thru component or hdmi you should be able to press the # button on your time warner remote to fill the screen. Hope this helps.
Posted on Feb 11, 2009
Can't pick up channels itv, channel4/5 and itv2 on my bedroom freeview tv and down stairs doesn't pick up film4 and a few others?? I have only recently connected the bedroom aerial to the ariel which was...
hi when fitting an new aerial line you need to put a splitter in the line.
4963215_1-oo4k03phwtyaxld0gomgkgbv-2-0.jpg it looks like this. they say satellite/tv on them this will stop interference from the boosters and the tvs on the same line, you connect it on the main arial line. you can then use both boosters if signal is weak but most digital aerials are good enough without them. it you have the right arial for your area. there are meany sizes. but say you are 15 miles from your tower then use a small aerial has the same fitting as this pic. that is out side aerials, inside aerials ie in loft you need a high gain aerial , long type. hope this helps. also if the aerial is not lined up it will not get great signal there is an app you can use on iphone or androids, tables etc to help you position the aerial in the right place it's called Uk aerial alignment . tool on app shows you the towers in your area and the best ones to use and shows you the aliment to the tower for best results. good luck
Jun 22, 2017 | Samsung LE40R74BDX 40 in. LCD Television
The sound is distorted and overwhelmed by static
Depends what the real problem is.
Is it related to certain sources only - try new or reseated cables,swap it to a different input; single channel - swap to isolate; or certain controls that have become noisy? A shop might be able to get some tuner cleaner into them.
Mar 12, 2010 | Panasonic SA-XR25 Receiver
I have a Samsung ln46b530 hdtv. One month. Just
I think the picture mode set by you or some one put in JUST SCAN MODE, go and check it back and should let it as 16:9. Else, you should play DVD and see if the line happen or not. If it still hapens, return it and exchange another one.
Jun 29, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Static on all cable channels
The tuner is questionable The problem lies inside the isolation box. Ask a repairman to open this isolation box and resolder the small board. There are two small resistors that need resoldered. This also has the rf connector on it. And you may have him resolder the tuner if this does not fix it. Have him inspect any and all grounds on the main board as well. Good Luck
May 31, 2009 | Toshiba CF32F50 TV
Small line of static at the top of the screen
i solved this by enlarging the picture size through setup, or the V-position.
Mar 26, 2009 | Vizio GV42L 42 in. LCD Television
Picture freezes on Sony Bravia 46 in
this can be a weak signal check the connections on cables. also in hot weather you can get a build up of static electricity and it will need to be discharged, turn off tv at mains and cross the connector and the cables if you have a buster or other box connected to them turn off and do the same to them. use something metal but make sure there is no power to them.
Jun 21, 2017 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Audiovox 9'' drop down tv with poor sound
You need to go to cable instead of air and search for channel
Feb 07, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Tv connector cable plug slips out
you need to replace your wall cable outlet. This can be purchased at any Radio Shack or Home Depot store. You will find two mounting screws , remove them and you will have access to the junction box. If the cable system was installed in the proper manner you will find a double male connector attached to the face plate by a single securing nut. Remove this nut and replace the double male connector. simple job, hope this was a help to you.
good luck----------------tomtaso
Nov 21, 2007 | GE 25GT240 25" TV
Some channels have no color or sound
once a signal falls below a certain threshold the color will be lost.
some sets are more sensitive to this loss.
if you see static in the picture on any of the channels then the cable is leaking and needs replaced /tightened.
if a local air broadcast is leaking into a same cable channel on the cable you will get poor to no reception on that channel.
for example : he we have a local channel 7 on the air.
if i tune to cable 7 and see a weak or distorted pic then the cable is leaking and needs replaced.
May 04, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Philips Magnavox 42MF521D/37 Television Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
