Question about Sony VAIO A250 Notebook
Want to connect my Sony vaio VGN-A250 to Sharp 19'' LCD TV
Hi, I want to connect my Sony VGN-A250 laptop to my sharp 19 inch LCD TV. My computer has only a vga at the back and TV also has a VGA (or RGB) if it's the same. Hooked up cable but not getting aything,. WIll appreciate your help. Thanks.
  • 3 more comments
  • Ken Balram Feb 11, 2009
    hi guys, thanks for the info but still I am unable to resolve the
    problem. I am using the VGA outut from computer to TV VGA input and
    using the FN key by pressing F7 but still nothing on the screen. Any
    ideas. Thanks
    yes i did!
    do you think that i need to get a wxga cable because my computer's lowest resolution is 800x600 and i regularly use 1280x800. The VGA cable is understand its for resolution 640x480
    no i am not using an adapter for the vga
  • John Cole
    John Cole May 11, 2010
    When you hook it up do you change the output on your laptop? It should be a F key that changes the screen
    Sergeant:
    Champion:
  • 237 Answers
Ok this may sound sill but do did you change the channels to the input for it?.
Posted on Feb 11, 2009
  • John Cole
    John Cole Feb 11, 2009
    Are you using an adapter for the vga?
  • John Cole
    Are you able to try a different cable? If so try that
    Novelist:
    Champion:
  • 201 Answers
Your laptop will have a VGA output or possibly a S-video out. For the VGA you'll need a standard VGA cable. Plug the cable in to your laptop and the PC input of your TV. If your TV does not have PC input it may have a DVI input. IF it does you can use a VGA/DVI adapter to plug it in. If it doesn't have a DVI input you can use the S-Video output on your laptop with a standard S-video cable. After the connection to your TV is made you will have to toggle alternate display by pressing and holding your [Fn] key and pressing F4, or F5, or another F# key. It's the one that looks like a TV screen. Press once to turn on output, press again to turn off your laptop screen, press again to go back to laptop screen only
Posted on Feb 10, 2009
Vaio vgn a250 saying that original battery is not genuine sony
This is because you didn't install the Sony Share Library or Sony Firmware Extension Parser.
As a work around you can disable the pop up with the following steps:
1) Click on Start
2) Click on Run
3) Type "MSCONFIG"
4) Press Enter
5) Click on the Startup tab
6) Scroll down and locate ISButility
6) uncheck it
7) Restart the PC
We Are Here To Help!!
Donald Deane MCSE,ASE,CPO
Aug 11, 2017 | Sony VAIO A250 Notebook
How to boot sony vaio laptop VGN-A250
enter bios and change your boot priority to include network boot.
Jun 25, 2012 | Sony VAIO A250 Notebook
I want to connect my Sony Vaio VGN-NR120E to my TV Samsung. But I have no idea how to do that. Could you give me advice ...
Your Sony vaio does not have any TV-out port to output the display on any analog TV. You can use your VGA (by using VGA cable) port to output your laptop on LCD / Plasma / LED TV (with a VGA port also)). If you still want to project to analog TV via the VGA port, you need to find a VGA to RGB adaptor. But bare in mind, it's hard to find one.
VGA port is like the port on computer monitor. RBG consist of three colored port.
Good luck ;)
Mar 09, 2011 | Sony VAIO VGN-NR120E/S Notebook
My lcd is really bright then all these black blocks coming from the right going to the left no pictures, laptop works with a external ok. What am I looking for?
Please restart the computer and press the F2 key to access the BIOS setup. If the issue persist in the BIOS also then the issue is with the LCD screen, in that case service will be required to replace the LCD screen. You may either contact Sony Service Center at:
https://eservice.sony.com/webrma/web/index.do
Or you may also contact your favorite hardware vendor.
Based on the information, it seems that those are dead pixels and a LCD replacement will required.
The following are the Display part numbers:
A1062138A- Sharp Display Model# LQ170M1LA04
A8119991A - LCD Harness
468257801 - LCD Hinge (L)
468257701 - LCD Hinge (R)
468238001 - LCD Hinge Cover
147862922 - LCD Inverter
Thanks!!!!
Dec 28, 2010 | Sony VAIO VGN-A690 Notebook
My problem is when I connect my laptop Sony Vaio (model: VPCEB18FD) at my TV Sharp AQUOS (Model: LC-42D64U) via HDMI cable (v 2.0), I don't have sound...... Thanks!
On the Vaio:
right click volume on system tray and select playback devices
select hdmi/ sdip as default and then in the properties deselect dolby
If you don't have those options you may need new drivers installed on your Vaio. Do you have windows xp? The driver can be found here: support.vaio.sony.co.uk/downloads/info/info.asp?site=voe_en_GB_cons&url=Vaio/Original/AR2_Drivers.zip&ip=RAID_AR21.htm
If you have vista the driver can be found here:
support.vaio.sony.ie/downloads/updates/updates.asp?site=voe_en_IE_cons&c=0&s=VGN-AR&m=2418&os=7&osl=1
On the television make sure you are on the right input. Press menu--setup--hdmi setup--audio select--digital
Hope this helps
Oct 08, 2010 | Sharp LC-42D64U 42 in. LCD HDTV
The screen on my Sony Vaio VGN A250 model PCG 8R7L is showing enterference is there a service manual from Sony for the Sony Vaio VGN A250 model PCG 8R7L I can obtain?
Hi kyle662919.
You may download the Service Manual from the below link:
http://home.comcast.net/~nw_systems/vgnA.pdf
Please open the above link to download the Service Manual for the VGN-A200 Series Notebooks.
Hope this helps.
Please feel free to contact for further assistance.
Jan 22, 2010 | Sony VAIO A250 Notebook
Not able to connect sony vaio to projector or LCD TV
The monitor switch on a Sony is usually done by holding down the Fn key and tapping one of the F keys that has the icon of a monitor on it, sometimes you have to tap that key a couple of time for the switch to activate.
Regards.
Aug 01, 2009 | Sony VAIO VGN-FE880E/H Notebook
Sony vaio vgn-a250
system is corrupted.
Jun 30, 2009 | Sony VAIO A250 Notebook
How do I connect my sony vaio vgn-fs920 to a tv?
As far as I know I need:
1) to purchase that VGA - S-Video Adapter ?
2) to purchase S-Video Cable itself ?
3) to purchase something like audio AV cables as well ?
Does anybody know where I can buy VGA - S-Video Cable (without Adapters) if it's possible and DO I NEED TO BUY AUDIO CABLE IF I'M GOING TO CONNECT THRU S-VIDEO?
May 14, 2009 | Sony VAIO VGN-FS920 Notebook
I lost my ac adapter for Sharp Actius A250 PC Notebook
office depot / neighborhood computer stores /mite try ebay or just typeing in search engine for sharp actuis cheap power cord ...lala linda
Jun 05, 2008 | Sharp Actius A250 Notebook
Sony VAIO A250 Notebook Logo
407 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
