Question about Philips Magnavox 15MF400T 15 in. LCD Television
Can't get Video Picture
Checked with Dish have cables set up correctly. I'm trying to get a picture and can't find the input button on my Philips15'' Flat TV Serial Number BZ1A0405 277686.
  • 8,596 Answers
On that model, the input botton is marked "TV/VIDEO"
-Tha Mp3 Doctor
Posted on Feb 21, 2009
I hit the SAT button by mistake and now the TV picture won't come back on- it says to hit input button but that doesn't work
Hi there, my name is Kimberly and I form part od the Social Media Department with DISH. If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2 (Our remote will not always work to change the input on your tv. We recommend that you use the original remote that came with the TV at the time of purchse or the Input/Source button on the TV itself). If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2)
If you are using COAX cables, then the tv needs to be on channel 3 or 4 (If you are at TV2, then the TV needs to be on channel 60 or 73)
If you have additional questions or need any type of assistance with your DISH service, feel free to reach me at: kimberly.escobar@dish.com
Kimberly Escobar
Social Media Representative
DISH L.L.C
Mar 20, 2014 | DISH Network DVR-625 DTV Receiver /...
Dish network Blue screen No "Signal
Hi john harrison!
A blue screen with "No Signal" is usually related to a video problem. The TV may be getting changed off the correct input/channel, or the video cable might be going bad.
If you have a spare, I would recommend a different cable and seeing if that fixes the problem. If it continues, verify the input/channel your TV is on when it receives a picture and if it goes out try putting it back on that input/channel.
If problems still continue I would be happy to review additional options with you. You can reach me here or at thomas.faust@dish.com
Tommy Faust
DISH Social Media Representative
Jun 03, 2012 | DISH Network Televison & Video
How do I connect my LG TV to my dish network
Hello Al, my name is Cheri Torres and I work with DISH Network Internet Response Team. I came across your post and wanted to see if I could help. Connecting your LG TV to your DISH Network receiver should be fairly easy, depending on the connections you are using. If you are using an HDMI cable you will need to connect one side of it to your LG TV and the other end into your DISH receiver, as long as you have an HD receiver. If you do not have an HD receiver you are probably going to want to use composite cables(red, white and yellow). If you are using either of these cables you are going to have to set your TV to an input in order to receive the DISH picture. You can select an input by finding a button on the TV remote or the TV itself that is listed as input, source, AUX, mode or video. You will need to cycle through each one until you find the DISH picture on one of them. Once you have the picture you will need to press SAT on your DISH remote and everything should be working fine from there. I hope this information is useful and if you have further questions feel free to ask!
Dec 31, 2011 | LG 42PG20 42 in. Plasma HDTV
How do i get tv to pick up channels?
Hi Meagan, my name is Cheri Torres and I work with DISH Network Internet Response Team. I came across your post and wanted to see if I could help. Connecting your TV to your DISH Network receiver should be fairly easy, depending on the connections you are using. If you are using an HDMI cable you will need to connect one side of it to your TV and the other end into your DISH receiver, as long as you have an HD receiver. If you do not have an HD receiver you are probably going to want to use composite cables(red, white and yellow). If you are using either of these cables you are going to have to set your TV to an input in order to receive the DISH picture. You can select an input by finding a button on the TV remote or the TV itself that is listed as input, source, AUX, mode or video. You will need to cycle through each one until you find the DISH picture on one of them. Once you have the picture you will need to press SAT on your DISH remote and everything should be working fine from there. I hope this information is useful and if you have further questions feel free to ask!
Dec 29, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
Trying to hook up to a new Dish network box that was sent as a replacement. Before I can go through the Dish set-up the TV picture blinks on and off constantly. I have replaced the HDMI cable, confirmed...
I would try using a gold plated HDMI cable. Often the problem is that the cable is not capable of sending enough frames per second. I replaced mine with a slightly better quality cable I picked up at Sears for $25.00 and the issue was not only resolved th picture quality was unbelievable. If this doesn't help just reply and I will address this with you further!
Daniel Busa
DISH Network
Customer Service
May 21, 2011 | LG 42LE5400 42 in. LCD TV
Hullo ... I have erroneously used the TV remote to change channels, where I should have used the TelstraClear remote to do this. I now get a "No Signal" box on the television and am unable to...
dana_derek,
The TV is not on the correct input setting or channel. Depending on your TV model and the receiver, you have a cable coming from the receiver to the TV. That cable could be a coax (screws in), RCA (yellow, white, red tips), component (green, blue, red, white, red tips), or HDMI cable. For all cables except the coax, the TV should be on an input setting. With your TV remote, you should have a source, input, or TV/Video button. Press that button and it should bring up a list of input settings. Each time you press that button it will scroll you down the list. Try each setting until you find the picture. I hope this helps.
Ray Calo
DISH Network
Jan 21, 2011 | Televison & Video
I have dish network and am trying to watch tv on my gateway plasma. how do i connect my satelite cable to plasma to get picture?
We would like to guide you through the connection process,but depending on what kind of receiver and TV you have this process may vary.Visit our "How to connect receiver" page here:http://www.dishnetwork.com/SupportSection/setup-receiver.
Once we have everything connected correctly, check what channel or input yourTV is currently on by powering the TV off then back on and noting the channelor input that appears on screen when the TV is powered on.
Steps for getting picture on TV1:
If you are using a Coax Cable to connect the receiver to TV1, check thereceiver's back panel for the output name. If your receiver has a "TVCH 3/4 out" (non-ViP Receiver): Tune TV to channel 3 or channel4, if it has "Home Distribution" output (ViP Receiver):Tune TV to channel 62 or 75. If using non-Coax (RCA,Component, or HDMI) to connect receiver to TV1, cycle through the inputs untilpicture appears (this information may appear on the remote sticker), mostTVs have a "TV/Video", "Input", or "Source" button.
Steps for getting picture on TV2:
Access "Modulator Setup" from TV1 by pressing "menu"then 6-1-5. Tune TV2 to the channel that appears under "TV2 Out" onscreen. If still no picture, change the "TV2 Out" mode fromAir to Cable, or if it's already on Cable, change it to Air. Then change thechannel of TV2 to what is now displayed under "TV2 Out".
If the issue is only on ONE receiver, unplug the DISH receiver for10 seconds and plug back in. It may take up to 5 minutes for the reset processto be completed. If you still are not getting a picture, connect anothercomponent (VCR, DVD Player, etc.) to the same TV, using same cable, same input,and same channel to see if it works. If it works give us a call at1-800-333-DISH (3474) for additional troubleshooting, if you don't get apicture with the other component, replace the cable.
Hope this steps help, and thank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Service Representative
Dec 02, 2010 | Gateway GTW-P42M303 42 in. Plasma...
Sound but no picture
Hook up the composite cables that come with the unit. Turn the TV on to the correct input. Turn the PS3 on using the power button on the unit. When you press the button continue holding the button until you hear a second beep....about five seconds. That should set the PS3 back to the factory output. If that corrects the problem you can set the PS3 to use whichever cable you want via the XMB.
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
Philips Magnavox 15MF400T 15 in. LCD Television Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
