Question about Tomtom RIDER GPS Devices
Tomtom rider will only switch on whilst under mains power and on
My tomtom will not switch on using battery power only , I have tried as tomtom suggested ie resetting to no avail
  • Anonymous Apr 18, 2009
    I have the same problem Will change battery and see if it fixes the problem
  • 3 Answers
If it will switch on when connected to mains or car charger then perhaps your battery has had it. My battery no longer retains charge even when not in use. Suggest try new battery.
Posted on Feb 12, 2009
TomTom Rider unit wont charge. Tried mains charger, USB connector and bike charger. Swapped out the battery and the unit boots up but that is just the charge in the new battery. Any help appreciated.
Power board is faulty, repair or replace. Workshop repair required. Oh, stop plugging a charger into the USB socket. It doesn'tlike it, thats for data transfer only. The round pin socket is the charger port
Oct 30, 2013 | Tomtom RIDER GPS Devices
My tomtom rider 2 will not turn on
My tomtom rider 2 will not charge on my bike and will not charge from mains electric, when i use my tomtom in the car it works.
Cheers Tim
Mar 23, 2011 | Tomtom RIDER GPS Devices
I have a Tom Tom One version 2.It suddenly started switching screen views without me touching the screen,then the following day simply wont switch on.The green charging light shows when its connected to...
Theory 1: I wonder if it is due to condensation? Try warming it for a while with a hair dryer.
Theory 2: The power supply chip/ battery has died and in the process caused noise which made the screen switch.
Have you tried connecting it to your computer?
Have look through the tomtom forums but sadly I think your only option is to undo it and do some measurements starting with the battery. It's worth disconnecting and reconnecting the battery to see what happens.
Not a fix but best I can do with no further info.
Feb 01, 2011 | Tomtom RIDER GPS Devices
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
Over loaded via 12volt mains adaptor
at great expense cheaper to buy a new one
Jul 31, 2009 | Tomtom RIDER GPS Devices
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Tom tom rider version not charging via bike cradle either via direct connection to the bikes battery or when connected to an aux power socket. There is also no sound while attached to the car cradle /...
I recently had a bit of success with TomTom. My TomTom Rider 1 did not charge on the bike cradle, there is a known problem with the early cradles. TomTom have developed a TomTom Rider 1 replacement cradle (updated) and if you push hard they will wend you one in the post free of charge.
Jul 27, 2008 | GPS
TomTom will not switch on even when it is plugged into the mains power
yes just press the reset button under the tomtom you can find this next to all the pins where your tomtom dock goes in.
Dec 17, 2007 | Tomtom GO 910 GPS Receiver
Tomtom RIDER GPS Devices Logo
304 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
