Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Control screen flashes F2 and F3; now oven element won't heat.
12 or 14 year old Kenmore electric range; self-cleaning; maybe this should just be replaced!
F2/F3 code accompanied by constant and repeated beep means it has to be shut off at the breaker box.
Replaced oven element; broiler was ok, though rarely used.
I'm suspecting fairly shabby construction, this device has probably outlasted its planned obsolescence.
Using the timer or timed bake control seems to go directly into F2/F3 and beeping.
  • 15,935 Answers
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
Self-cleaning electric range
Hi
Here are the codes for you range:
F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1Safety flip flopReplace Electronic Range Control/Clock (ERC) F2 - E0Shorted keypadReplace Electronic Range Control/Clock (ERC) F3 - E0Oven temperature sensor or oven temperature sensor fuse openedReplace oven temperature sensor or fuseF3 - E1Oven temperature sensor shortedReplace oven temperature sensor F3 - E2Oven too hotReplace oven temperature sensor F3 - E3Clean temp too hot Replace oven temperature sensorF5 - E0
F5 - E1 and E2 Door latch problemCheck door/latch switch, replace if necessary
Looks like yours is a bad oven control. There is a # at the end of yourmodel # 0-5 that will determine which control it takes. Once you havethat # you can look it up at http://www3.sears.com/ Looks like the part costs about $165.
Oct 08, 2008 | Kenmore Kitchen Ranges
My older model electric hotpoint selfcleaing range, lower oven self cleaning function is not working. what could be wrong, maybe i didn't set a control knob correctly, don't have a maual for t
Back to the fifties! If the lower oven cooks normally, the heating element probably is OK. For self cleaning the normal temperature setting is bypassed and the heating element is set to a substantially higher level. Your oven may be unable to self clean because operation of the knob may not actually start the cycle. The thermostat could need replacing even though normal cooking is OK.
Sep 02, 2012 | Hotpoint Kitchen Ranges
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
Oven keeps flashing E1-F3
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 22, 2010 | KitchenAid KERC607 Electric Kitchen Range
Kenmore Electric Range Model # 790.95664100 All display lights are off until you turn on a heating element control knob. Then the time display starts flashing "12:00" along with a short buzzing sound...
Sounds to me from the information you provided that the auto timer is set...when the auto timer gets set you are generally unable to use the oven. If the auto timer is not set then you are looking at a problem with the Electronic oven control..do any error codes show up f1 - f2 - f3 and so on?
Jun 23, 2009 | Kitchen Ranges
F2 f3 starts beeping when using stove or oven
F2
Oven temperature too hot
Check and replace oven temperature sensor (RTD).
F3
Open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
So i suppose its a sensor replacement is necessary.These are the fault code explanations by frigidaire.good luck with the machine.Please do post results and comments.
Apr 15, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
May 21, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
610 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
