Question about D-Link AirPlus DI-524 Wireless Router
Windows xp wont connect to internet
im using virgin broadband with a d-link dir-301 router, and on my pc I am using the d-link supplied dongle.
On my macbook and iphone and other peoples laptops etc they can connect fine to the wireless, but with my pc it wont connect.
I can sometimes find the router in my network list, sometimes not. When I try to connect to it whenever it is listed, it connects to the network, but not to the internet.
If i try to repair the connection, it doesnt work, and disables the network connection through the dongle, and any attempt to 'enable this network device' fails straight away.
I have gone into advanced wireless settings and added a preferred network, but this doesnt help.
When I try things again and try to connect, it just sits on the screen - 'waiting for network', then says 'aquiring network address;, showing a low signal, and at that point it stays there, but still isnt connected!
Please help!!
Im running:
windows xp service pack 2
1.85ghz amd athlon xp
nvidia nf7-s2 nforce
Please check you LAN settings on your router (DNS) - usually it is 0.0.0.0 (assigned by provider)
Make sure your PC is using DHCP (TCP/IP properties -> Obtain IP Address Automatically & Obtain DNS server address automatically). Try "ipconfig /all" at others computers and compare with your PC (look at gateway & DNS). See if you can ping gateway and then outside address.
p.s. To access your router open Internet Explorer and enter http://192.168.0.1/
If it is not working, check the default gateway address on working computer and use it instead.
Posted on Feb 14, 2009
The setup wizard does not show the connect button after following the steps. So we cannot connect to the internet using the dlink dir-412 router.
For each PC that needs to connect to the DIR-412 wirelessly, you must ensure that the correct Wireless Network Name (SSID) and encryption key has been entered.
Windows 7 On your computer, go to Control panel --> Network and Sharing Center and Click on "Connect to a Network then select on the Wireless Network Name (SSID) and enter the password/encrytion key.
Windows XP On your computer, go to Control panel --> Network Connection then under the network task pane select View available wireless networks then then select on the Wireless Network Name (SSID) and enter the password/encrytion key.
Jul 25, 2011 | D-Link DIR-412 Mobile Broadband Wireless...
Dlink dir-142 Dodo usb prepaid dongle t12146l140 no connectivity optus usb prepaid dongle e169 responsive, no internet coverage connects with nintendo 3ds but no internet connection. windows xp...
plug the usb modem into usb slot of pc as normal.
Bridge the connection between the internet connection and ethernet router connection in network page.
Set router to ip add etc and it should share net access while pc is turned on atleast.
Jun 14, 2011 | D-Link DIR-412 Mobile Broadband Wireless...
I have a broadband connection and have 2 computers.i want to split the connection so that both machine can use the internet at the same time..should i use a switch or use a router..am confused..i wanted to...
Hi
when you use the broadband connection you must use router to split the connection .
so I suggest you use broadband router like DIR-120 Or DIR-330 for wireless..
you can choose what you need from here
Apr 24, 2011 | D-Link Computers & Internet
Trouble replacing a USB modem with a Dlink 615 on Virgin Media
First: Turn off your USB modem.
Second: Setup your D-Link for connection
Feb 25, 2010 | D-Link DIR-615 Wireless Router
One PC will not connect to Router and therefore Internet.
Sounds to me like the problem is related to the PC hardware. Please check the following in your PC:
- Network card is properly working
- Network cable connecting to the PC is properly working
Sep 21, 2009 | Belkin (F5D5231-4) Router
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
Connecting a router
To connect more than one computer to same network, you need to use a router. Two modems will not work on same network.
My suggestion:
Buy a wireless modem router for cable broadband (and eventually a wireless network card for the other computer.
Here is an example: Linksys BEFW11S4 Wireless-B 4-Port Cable/DSL
Ask retailer to get right model for your broadband.
Connect the remote computer with wireless.
Apr 22, 2008 | Computers & Internet
I HAVE A BELKIN WIRELESS G ROUTER (F5D7230-4) WHICH WORKED WRLL WITH MY WINDOWS XP AND VIRGIN BROADBAND. MY NEW COMPUTER IS VISTA THE ROUTER WILL NOT WORK. IS MY ROUTER INCAPABLE OF USING VISTA?
Check to see if your wireless card/dongle is working,and installed correctly.
Check at the manufacturers wesite for Vista Compatability
Apr 21, 2008 | Computers & Internet
Wireless
Just typr 192.168.0.1 into the add bar on internet explorer and it will take you into the router so you can set it up. You will need to be connected to it by a lan cable to do this.
Hope that fixes it for you?
Jan 05, 2008 | Microsoft Office Outlook 2003 for PC
D-Link AirPlus DI-524 Wireless Router Logo
232 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
