Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
No audio, but not all off the time. Doesn't work with dvd either.
Occasionally it will work when I turn it off and turn it on again.
  • 16 Answers
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the
PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with
electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at avsforum.com/avs-vb/showthread.php?t=647174&page=13 for pics of the information detailed here.
My knowledge of how to solve this issue came primarily from finding the research efforts of ‘Aureius’ on the AVS forums, and particularly from his taking the time to post the solution publicly so that others might save time, money, and aggravation. I'm just passing along the information. Thanks Andy!
I also wanted to mention that a couple of other very pesky common problems with these series of Sharp TV's involving symptoms of random powering-off and/or powering-on, and 'function lock-ups' of various sorts are easily remedied through two firmware updates (Main CPU: PH1UU112, Monitor: MD1UA104). These are not available to end-users via the internet but it may be possible to get the files from an understanding factory-authorized repair tech. They are installed using an SD memory card (don't use the HC high capacity sort, use only those that are NOT HC) which is inserted into a special slot in the back of the machine. For those of the DIY persuasion, information about how to check whether your TV has old firmware in need of an upgrade is readily available through internet search.
Posted on Feb 16, 2009
  • 335 Answers
Check your input connections for proper fit and identity..... you may have a problem developing in your audio path inside your tv.... this will require technical servicing....
Posted on Feb 11, 2009
My down button on the volume control doesn't work
a good after market radio would be cheaper than sending the original out for repair
Aug 25, 2012 | 1995 Ford Mustang
Need to know program code for a toshiba blueray/dvd
IF ABLE TO TURN ON THEN, JUST KEEP PRESSING THE POWER BUTTON ON REMOTE TILL IT RECOGNIZES AND SHUTS OFF. THEN DO THE SAME AGAIN TO TURN ON...IF THIS DOESN'T WORK, THEN START AT 01, 02, 03 ETC,. TILL IT TURNS ON!
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Audio Players & Recorders
I have an HK AVR 355 system, that worked just fine. Yesterday I tried to hook up a new TV, and ended up taking a few cable out since they were not imoportaint any more and only used HDMI cable. Now when I...
Obviously you removed (or disturbed) something that was really necessary to the DVD's digital audio path. "Doesn't work" is pretty non-specific.
Do a web search for "HK AVR 355 manual" and download it. Then read the part about assigning digital audio sources and speaker configuration setup.
Look at the Troubleshooting Guide part that mentions the Channel Indicator Display (page 33).
Aug 17, 2011 | Harman Kardon Audio Players & Recorders
For some reason, I get audio for the visually impaired when i play a DVD. The original sound of the DVD plays but an additional narrative (describing each scene) plays as well. The DVD is a recent...
Generally, remote controls for DVD systems have a button labeled "Audio". This button changes which audio track you will hear during the movie. Common tracks include English, French, Spanish, Commentaries, and occasionally Audio for the Hearing Impaired.
It seems odd for the latter audio track to be default, but clicking the Audio button until you have the plain English track should work. I would consult the manual if you have it on hand to see if your system is capable of remembering which track to start on.
Hope this helps.
Jun 13, 2011 | Protron PDS-2315 Theater System
My LG LCD TV occasionally only turns audio on only when I press power.No picture, it only happens maybe 3 times a month but I would love to know why is this happening
I have personally experienced the same issue with an LG LCD of my own. It seems to be resolved by turning the television off and back on again. I would suggest this is a hardware problem that will be worth contacting LG about if the television is in warranty, to ensure it doesn't get wore in the future.
May 04, 2011 | LG Televison & Video
DMR EZ47V freezes occasionally, will not play certain discs
i hope ,too.if its only months since you bought that ,avail of the warranty package that comes with it.
May 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Random no audio
I have had this happen with this particular brand frequently. I have it plugged in to a power "strip" or surge protector. I find that if I turn the strip off then on again, it resets and fixes the problem.
Feb 18, 2007 | Cyberhome CH-DVD 300 DVD Player
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
210 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
