Question about Garmin StreetPilot c340 GPS Receiver
Will not turn on
While putting in a new address, it shut off, I tried plugging it in and now it won't turn on at all.
  • tygermouse Feb 11, 2009
    I turned it on, it started up then shut off and won't turn back on.
After charging, try prying off the silver thig that surrounds the screen. You'l find a reset button. Press it and see it if starts up. You'll lose saved destinations, but it worked for me.
Posted on Mar 06, 2009
    Sergeant:
    Champion:
  • 373 Answers
Give this a try
I found this one on the problem solve on here
Plug in your gps for 12 hr to charge fully
then try it.
The charge for gps on battery is 3 to 4 hr
Posted on Feb 18, 2009
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Engine turns over about 3/4 of turn,won"t start,been running good,new batt,new plugs,new air filter
check and see if you have gas in the oil if you do rebuild carb if not replace starter is bad
Jul 12, 2014 | Garden
Kohler courage 25
check for gas in the oil if not bad starter
Sanyo vpc-s1213 12 megapixel, 3x optical zoom lens stuck out, won't turn on
Mine did the same thing after I put in a new sd card. Finally after trying everything else, took out the sd card and it worked.
Apr 10, 2012 | Cameras
Car turns over but won't start.
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Feb 07, 2012 | 1999 Lincoln Town Car
I have a 91 olds supreme 3.1 v6 it shut off and won't start back .... It starts but won't turn over.... And when turn the key back off it's blows the dis fuse wich mean direct ignition system...
Check the coils that have been replace for bent or broken prongs that plug into the ignition control module and if nothing looks damaged then i would think the ignition control module is faulty.Replace ignition control module.
Jan 21, 2012 | 1991 Oldsmobile Cutlass Supreme
I have a toshiba laptop satellite L-300 that won't turn on. I tried unplugging AC and remove the battery and hold the power button for 30 sec. and plugged the AC back, i can see the green light at the...
THE BATTERY LIFE TIMED OUT.TRY IT ON NEW BATTERY FOR TURNING ON THE SYSTEM.THE CHARGING ADAPTER MAY BR ALSO A PROBLEM TRY TO CHECK IT AC VOLTAGE LEVELS .
Sep 03, 2011 | Computers & Internet
Dryer won,t heat, put in new element and still won,t heat.
check you thermal fuse for continuity if none change it and the high-imit safety shut-off fuse(closest to heat element)
Apr 08, 2009 | Dryers
Local area connection shows unplugged
try to check your domain,the ip address,the default gateway.your nic card check,if its installed properly.maybe its disable
Mar 29, 2008 | Computers & Internet
Garmin StreetPilot c340 GPS Receiver Logo
71 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
