Question about Powerware Best Power Unity/I UPS System
Unwaranted UT3K UPS check battery warning
The UPS is question is a Best Unity/I single phase UT3K. New batteries have been placed into this unit, they are maintaining correct voltage, and when the battery load test is run they pass. From turning the unit on after around 7 hours the "Check battery" warning alarm A-04 is displayed and cannot be cleared. If this unit is turned off and on again the alarm does not reappear for another 7 hours or so and the unit will also pass the battery test. I don't think there is anything wrong with this unit, but I don't like to leave it running with the alarm. Perhaps I need to edit one or more of the many many internal settings?
Any thoughts?
-Thanks
  • 3 Answers
Hi!
1) By the way, batteries are really new (or "China new")? ;)
If they really new then maybe not start-formed. In this case after little time they will get steady (end of problem). If they are "China new" - it worse, their real capacity usually less then 75% from declared.
2) Try to check batteries connectors, wires and their eyelets. If there is weak contact - charging will be wrong (low current)...
3) Check small orange (voltage sence) connector...
4) Look, what happened with P-62, P-63, P-74 ang P-75 settings? maybe there something is wrong...
Maybe, it will be helpfull?
P.S. Please, excuse my weak english.
Posted on Apr 14, 2009
Alarm light
You need to reconfigure for the new batteries. Enter the stack numbers but you need the password to do this. You need the Service Manual to perform this config.
Apr 30, 2013 | Powerware Best Power Unity/I Three-Phase...
@MY APC UPS SURT15KRMXLI is not charging after installation on single phase input
we have installed a new ups but the battery light indicates red light even though its on charge
Aug 12, 2011 | APC SMARTUPS RT 15KVA RM 230V...
How to adjust the display screen britness
Here is the documentation page: http://www.zoomerang.com/Survey/WEB22BKRKCECDW/
You can also contact Eaton. They purchased Powerware about 6 years ago. They retained the Best Power/Powerware service network and technicians:
Toll Free: 1 800 843 9433
International: +1 919 871 1800
E-mail: LargeUPSTS@Eaton.com
Dec 12, 2010 | Powerware Best Power Unity/I Three-Phase...
NEED PARTS FOR A UT360 UPS. NEED DISPLAY/KEYPAD AND COOLING FAN WHERE CAN I FIND A ON-LINE REPAIR MANUAL AND PARTS?
Hi, Eaton bought Powerware in 2004 and assumed the service for Best Power products. Here is the URL for legacy UPS products like the Unity/I: http://powerquality.eaton.com/Products-services/Legacy/Legacy-Products.asp You'll need to scroll down to the very end of the UPS section. In regards to parts and service, here is the contact info:
Oct 29, 2010 | Powerware Best Power Unity/I Three-Phase...
My ups is not able to store energy
You probably need to replace the batteries. Although it probably has a Best Power logo, Best was eventually acquired by Eaton and they still service the type of UPS you have. You can call Toll Free: 1 800 356 5737 or e-mail: SinglePhaseTS@eaton.com
You can visit this page to see the user manual: http://powerquality.eaton.com/Products-services/Legacy/Legacy-products.asp
Sep 15, 2010 | Powerware Best Power Unity/I Single-Phase...
How to solve single phase lost in UPS at input end
What size UPS and make and model?
First make sure your utility is reaching the UPS and it's not on that end, sounds like the problem might be with your input power not the UPS.
If power is getting to the unit, you may have a failed power component internally, such as a fuse or transistor.
Nov 05, 2009 | Zenith ZTG Nema-3R, 400 Amps Three Phase,...
A-12 Alarm wont go away
I have an ut8k UPS I am getting an A-12 alarm. On the cover it means "tap the regulator alarm. I opened up the unit ...
May 28, 2009 | Powerware Best Power Unity/I Single-Phase...
Alarm mode question
sounds like battery failed, check the connections and clean them, then try it again. see if the battery is ok, check voltage, and shake the battery, if you hear little objects rattle inside, it is bad. i hope this is helpful,good luck,glen also consider the unit could be shot.
Feb 11, 2009 | Powerware Series 9 9150 UPS System
Batteries
If you go to www.batteryinternational.com they can help you locate the correct battery for your UPS system. Hope that helps
Feb 11, 2009 | Powerware Best Power Unity/I Three-Phase...
Powerware Best Power Unity/I UPS System Logo
185 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
