Question about Ford Garden
Furguson/ 8N Ford tractor 1950's model schematics
We have just recently aquired an 1950's model Ferguson tractor. I need to know where to check the oil in the engine, transmission, rear end and such. Also it has a Lp gas burning engine. I need to know about adjusting the fuel flow or something, because it acts like it's starving for fuel when ever you rev it up. Any info on liquid verses vapor would be very helpful also.
Thanks so much in advance!
Peggy
  • 218 Answers
Hey Peggy..my name is Keith..and i restore 9N and 2N Ford Ferguson's and also the 8N's ..but the are strickly Ford..but Ferguson made his own tractors starting in 1949..and the model numbers was a TE-20 a TO-20 and a TO-30..Im not quiet sure what you have ..but a Ford and Ferguson the oil dipstick is located on the left hand side of the engine..and the transmission/hydraulic(its the same fluid) oil dip stick is located on the right hand side..just above the the back of the running board..and as for running on LP..i have not worked on one that was LP so i cant help you there..i hope it helps..and if not..please write me back
Posted on Jun 30, 2009
Cannot turn distributor by hand on a 1950 ford 8n
It is frozen, hit it with a soft faced hammer.
Sep 22, 2016 | Ford 8N Tractor
Will curved and straight hydraulic control arms interchange? 1950 8n ford
probably not as curved arms will be designed with a curve to clear an obstacle like an axle
Sep 05, 2016 | Ford Garden
How can I get a copy of a wiring diagram 1950 ferguson tractor 10-35,with 12 volt gen.
perhaps a FORD tractor dealer could find one for you
Mar 03, 2016 | Toys
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
FORD 8N TRACTOR , CAM SHAFT THRUST SPRING , HOW CRITICAL IS THIS SPRING
For the best answers to your question ask Robert Sybrandy, Technical Advisor for Ferguson Enthusiasts of North America
r_sybrandy@yahoo.com
or Rob Rinaldi of N-News magazine infon@n-news.com
Sep 10, 2014 | Ford 8N Tractor
Does the pto have anything to do with the lift on a tractor?
Sometime around 1950 Ford tractors started using "live PTO". Prior to that the power lift for equipment required that the PTO be on and running (turned on by a lever on left side of chassis below the driver's seat). So 'yes' the older tractors (many in use today) require the PTO to be running in order for the lift arms to lift equipment. I find this very annoying when trying to run a mower, especially when the hydraulics don't hold very well.
Jun 27, 2014 | Ford 8N Tractor
1950 massey ferguson timing gear alignment
what are the timing marks for a massey ferguson tef 20 1955 to put the timing back on
Apr 16, 2012 | RTO Massey-Ferguson Tractor TE20, TO20,...
I changed my 1950 ford over to 12 volt and it sat for over 1 year now it wont start so I changed the solinoid ,and ignition switch ,battery,battery terminals and it still wont start and no lights
hey
Recheck the battery connections for crud.Clean battery post/cables and where cables connect to the frame and starter solenoid as sometimes the tractor power feed is at the solenoid.
Good Luck
O if you have a meter or 12volt trouble lamp you can measure across the connection for a voltage drop. With the lights in the on position.
Jan 27, 2011 | Ford Tractor 8n Front Emblem
The steering column shaft in my 1954 Ford 8N tractor broke and I need info on howe to fix it.
Not sure, but if it's a 1954 model, it's not an 8N. 8N was only built thru 1952.
But sounds like you will need a new steering shaft.
www.Ford8N.com
Sep 19, 2009 | Ford 8N Tractor
1950 8N FORD TRACTOR WON"T START.
Hi..my name is Keith..and i have 9 ford tractors..i have 9N's..2N's and 8N's..and i have converted one or two of them over to 12V..and i use the solonid that has only 1 side post...and thats what my original starter swich connects to and on the big terminal i have the battery wire and a 12 gauge wire that i run to the amp meter....i hope this helps..and if you have any questions..please write back
Apr 13, 2009 | Ford Tractor 8n Front Emblem
Garden Logo
616 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
