Question about Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe - Coffee Cold,Lights not working
Hi - My Saeco Magic Deluxe goes through the brewing process as normal but the coffee comes out completely cold. The dispensing tube will not give steam or hot water - the water comes out cold. The function buttons will not light up when pressed but still seem to activate their functions. The red warning lights are functioning ok.
  • 3 Answers
The thermoblock (boiler) element is burnt out and must be replaced.
Posted on Feb 19, 2009
Our Saeco Magix Deluxe (old style) has developed a leak. It happens inside the machine, on the left, and is pretty severe, during coffee making. Sometimes there is just a little coffee ground in the...
Hi
When the machine is done brewing some water is relieved into the drip tray. This is the pressure relief. Some coffee residue is also taken into the drip tray. This is normal. As long as nothing is under the machine your OK.
Oct 23, 2010 | Saeco Magic De Luxe Espresso Machine
My saeco magic deluxe, doesn't make coffee all the time, it seams the brew group arm is not riseing and the coffee gets dumped in the tray
Sounds like early stage of stripped gears in Gear assembly or faulty Main electronic board. These are the 2 most common problems.
Mar 28, 2010 | Saeco Magic De Luxe Espresso Machine
Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Dec 08, 2009 | Saeco Magic De Luxe Espresso Machine
My Saeco magic deluxe needed the circuits relaoded. I followed the intructions and now my machine tamps first and then grinds the beans leaving me with weak coffee can anyone solve this for me ?
try this.
hit the external dosage button. Its the button on the top middle that controls when you want to put grinds in from the external shoot.
Do not place any coffee in there. then just press the normal brew button. it should brew more or less a cup of water.
then try brewing a coffee like normal and see if the problem fixes.
this happens because there is a little door in the grinder that hits a microswitch that tells the grinder to stop grinding.
This is supposed to happen when the grinder fills the brew group enough to click the microswitch.
Sometimes it does reverse itself like this.
The only other solution would be to open the grinder up and vaccum all grounds out and vaccum the grind shaft above the brew group on the side.
This will cause the door to go back to normal position.
If it doesn't work after that, the door or microswitch has gone faulty. But that is an extremely rare situation.
Hope this helps.
Oct 03, 2009 | Saeco Magic De Luxe Espresso Machine
Temperature control on Saeco magic deluxe
No it cannot. I am not sure why you would want the water hotter. It is designed to be at the perect temperature for passing through the brew group for coffee brewing, its kind of a simple science.
If your machine has been producing less hot coffee gradually, that marks an issue. Try descaling the boiler per the manufacturer's inscrutions even if the warning light isnt on. The other option is that the thermal fuse mounted to the boiler is bad and turns off the boiler prematurely, those cost about $15 and are simple to replace. Lastly, the boiler heating element may be 'burnt out' new boiler is $120+
Aug 15, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
Coffee comes out cold
sounds like you just need a new coffee pot, the heater inside must be shot.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic deluxe - no water flow
How old is your machine?
Do you descale it regulary?
I think it´s your boiler that has to be replaced
Aug 05, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
298 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Mike Cairns
Mike Cairns
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
