Question about Dell Inspiron 2200 Notebook
Acer Ferrari 3200 won't boot
I am a computer repair technician and have just purchased a faulty Acer Ferrari from someone who took out the battery whilst the laptop was switched on. The system appears to have power as CD/DVD drive works, lights for power and battery come on, fans start up, but there is nothing on the screen. I have done all the usual tricks, boot no battery, complete discharge hold on switch for 10 seconds and reboot, remove RAM, HD and DVD drives etc but still nothing. Have tested with external monitor too.
The power LED is flashing from amber to green constantly as though its in standby mode or something but I cannot find anything on the web for the LED flashing error codes.
Does anyone know what it might be? If its a mainboard then its an eBay job but if not then I will attempt a repair.
  • Dell Master
  • 2,404 Answers
Try different memory just to be sure its not that and if still no boot then its the motherboard.
Posted on Feb 10, 2009
Acer mobile not getting switched on
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you. If this does not work then -
Just like you sometimes need a mechanic to repair your car,sometimes you do need a technician to diagnose and identify the fault or faultson your computer. Not only does a good service technican have the experience todeal with this type of problem, they also have the equipment that allows themto look at things the average computer user can't see, and he has a collectionof replacement parts that can be used to quickly test individual components onyour computer.
Apr 20, 2012 | Acer Aspire Ferrari 3000LMi Notebook
My laptop is not starting when I plug in adopter the charging light shows but when I press start button light goes off and it does not start. Is this a battery problem. I always use the charger/adopter to...
Try removing the battery and then starting the computer with the power cord. Sometimes the battery is bad and prevents the computer from working properly.
Aug 02, 2017 | Acer Ferrari 3200 Notebook
I am trying to located the area to replace the BIOS Battery on the system
I couldn't find any information about the cmos location, but I've seen videos on finding it on other computers, and you have to get down below the keyboard to find it. On some computers, it can even be beneath the cpu, but on others it's at the front, and easily accessible. You can check out some videos on YouTube, and they show the process on certain computers- that will give you an idea of what you have to disassemble. Otherwise, you will need a service manual, and here is a link to one:
http://www.user-guides.co.uk/cddownload/Acer/AcerFerrari/Acer-Ferrari-3200-Service-Guide-Manual-Disassemble-Remove-Replace-Repair-51159.html
Good luck, and hope this helps.
Jun 28, 2010 | Acer Ferrari 3200 Notebook
(ACER ferrari 3200)earphone and disc drive
The headphone jack is soldered directly to the motherboard. finding a new one and getting it soldered on is the only option. As to the dvd I would remove it (one screw holds it in either on the bottom or under the keyboard) finding the model number and ordering a new one on ebay
Jul 15, 2009 | Acer Ferrari 3200 Notebook
My acer travelmate wont boot just beeps 4 times i recently reinstalled XP Pro os on acer ferrari 4000 and have recieved this same problem 4 beeps and black screen.won't boot..bios or os. HELP
I long + 3 short beeps or 3 short + 1 long beeps indicates memory problem.
The RAM module/s may need reseating to re-establish proper electrical contact.
If it still doesn't boot up then :-
Get the RAM module/s may be faulty, test the module/s in another laptop or get your friendly computer shop to test them.
May 07, 2009 | Acer Ferrari 4000 Laptop Notebook
Acer Ferrari 3200 Not Loading
when u turn on the latop try pressing f8 and then select option last good known configuration ..................................Sameeraryan
Jan 04, 2009 | Acer Ferrari 3200 Notebook
Hard drive
To change a drive is not hard at all,ones u can identify it then un screw the ferrari 3200 and replace the drive.Note:while replacing u must take note of how u un screw it and where u un screw it and make sure u dont lost any screw or misplace the connector when u are screwling the drive back.and before u replace any drive at all make sure the system is off and make sure to romove the battery b4 removing any drive to avoid burning of the motherboard.
May 14, 2008 | Acer Ferrari 3200 Notebook
Acer ferrari 3200 pc notebook problem
Hello. Vista needs a repair. You will want to start by putting in your own vista disc or borrowing one from someone. If your laptop isn't booting from the disc, then enter the bios (by hitting f2 or f12 usually) at bootup and select the DVD/CD rom drive to boot first. When the vista disc loads you will want to select recovery tools. Then select "startup repair". That should fix your problem.
Apr 12, 2008 | Acer Ferrari 3200 Notebook
Acer ferrari 1000
well I hope you got some knowledge on how to open the thing up or you will need to get the service manual
OK the power on password is the bios password
To reset the bios password
1.) open the laptop
2.) Remove the laptop battery
3.) on th main board is another battery remove that as well
4.) hit the power button(it will be a switch which the button pushes) 5 times
5.) replace board battery
6.) reassemble
7.) THAT JUST RESET YOUR BIOS AND BIOS PASSWORD,
enter setup and load optamised defaults and your set
TO REMOVE WINDOWS PASSWORD
1.) download hirens boot cd from here www.phazeddl,com
2.) boot from cd
3.) USE THE WINDOWS PASSWORD RESET TOOL TO RESET YOUR PASSWORD
4.) YOUR DONE
good luck
Jan 09, 2008 | Acer Ferrari 3200 Notebook
Dell Inspiron 2200 Notebook Logo
200 people viewed this question
Alun Cox
