Question about Meade ETX-125EC (500 x 127mm) Telescope
Can't focus the gears that are used in focusing are stripped out am trying to find out where to get repaired
  • 3,186 Answers
Unless you can find another "used broken" ETX of same model-- to get the focus off of-- your only recourse will be to send it back to Meade for repair--
Here is their customer service phone number-- and their manuals
http://www.meade.com/manuals/index.html
http://www.meade.com/support/contact.html Contact number
Posted on May 20, 2009
Focus knob not working
First of all, make sure the projection lens is correctly inserted. The gear "rack" that runs down the side of the lens correctly should mesh with the white or black gear (color depends on gear vendor) that is pressed on the focus shaft.
Check to make sure the focus knob is secure on the focus shaft (when you turn the knob, the shaft should turn, too).
Finally, remove the projection lens and inspect that black or white gear on the focus shaft inside the projector: Is the gear present, and are all the teeth on the gear?
One or a combination of these 3 issues are more than likely the cause of your problem.
Let me know if I can assist further !! Jim
Mar 04, 2013 | Kodak Carousel 600 Slide Projector
Hi I cannot get my F80 to autofocus. I have tried all my lenses on my Brothers F80 and they all work fine on his camera. I only bought the camera second hand a few days ago and i'm 99% sure when the...
If the gears are stripped, it will require an experienced tech to repair.
That being said, there should be a small switch near the lens mount to switch between auto and manual focus mode's, be sure that that switch is pointing to A. When set to M, the little screw recesses into the mount so it doesn't try to engage, when set to A, it'll extend very slightly.
Also, Nikon has manufactured two types of AF lenses - with the motor in the body and with the motor in the lens, as with most newer lenses. Your camera should have a small screw on the lens mount that drives the focus motor between the lens and the camera, but I'm not 100% certain on that. Your camera can focus lenses with and without this type of coupling. BUT, if that screw/motor in the body is not functioning, you'll only be able to use lenses which contain the focus motor inside them, or manual focus lenses (you can manually focus AF lenses too).
May 19, 2011 | Nikon F80 35mm SLR Camera
Auto focus drive not working. Makes a grinding noise and nothing happens. Sounds like a gear has stripped.
First try to use another lens If:
A. It does the same thing, bring your body to a camera repair shop.
B. It doesn't, you'll need to either buy a new lens or repair it at a camera shop.
Apr 20, 2011 | Sony Alpha 230 Digital SLR Digital Camera...
My 100-400 lens sounds like gears are stripped hear gears grinding when camera trying to auto focus - is there someplace to repaired and is it worth repairing
You have a no-name branded and almost worthless lens which will have absolutely no after-sales support any more.
Repairs are therefore not cost effective and probably not possible. Just use the lens in manual focus mode from now on.
Mar 07, 2011 | Phoenix Gold AF 100-300mm f/5.6-6.7...
My Canon powershot A1100 IS is not focusing at all. The lens extends when turned on, but when it tries to focus (when set to "Auto"), I hear a clicking sound, as if the motor is trying to adjust the lens,...
The focusing gear on that motor is stripped and the lens cannot focus. Not cost effective to repair. Canon will charge small fortune for the part and then the LABOR. Workiing on those small cameras is one royal PIA and labor intensive.
Sep 02, 2017 | Canon PowerShot A1100 IS Digital Camera
Focusing wheel is moving but it is not focusing at all
You can disassemble the focuser (look underneath for the screws, and look inside and see if the gears are actually engaging or STRIPPED.
Sometimes there is a screw that adjusts the tightness of the focuser.
Sep 26, 2010 | Leica Televid 77 (60 x 77mm) Telescope
The rack and pinion gear on the focuser for a meade ds 2000 telescope got stripped. I can't find replacement focuser .
You can possibly buy another focuser from Meade here:
http://www.meade.com/support/index.html
Orion Telescopes also sell focusers here:
http://www.telescope.com/control/telescope-focusers
Jul 21, 2010 | Meade DS-2130ATS (250 x 127mm) Telescope
The auto focus on my Sony A is not working. It
Usually the gears will strip the lens gears which tend to be plastics whereas Sony a cameras themselves have metal driven cogs....I once stripped a sigma zoom using an
A700 simply because the motor on that camera had no feedback on torque...put a different lens to check this out first...then check the faulty lens the cog is visible once you remove the rear mount.
Nov 11, 2017 | Sony Alpha DSLR-A100 Digital Camera
Gearbox wont stay in reverse
strip and repair job is only soloution the selector is worn or the gear its self is cream crackered
Nov 19, 2008 | 2000 Ford Focus
Stripped gears on the focuser
Meade will not have parts, focusers are always replaced as an entire unit-- but if the mirror is still good you can buy a replacement focuser here:
http://www.telescope.com/Accessories/Telescope-Focusers/pc/3/51.uts
and here:
http://www.optcorp.com/ProductList.aspx?uid=105-175-343
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Dec 25, 2007 | Meade Optics
Meade ETX-125EC (500 x 127mm) Telescope Logo
167 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
