Question about Kenmore 15516 Mechanical Sewing Machine
Thread is bunching underneath fabric
The thread underneath the fabric bunches up and looks like spaghetti. I have tried rethreading the machine, rewinding the bobbin, tightening the tension on the upper AND bobbin thread
  • 202 Answers
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
Posted on Feb 11, 2009
My thread keeps looping on bottom Have changed tension, needle rethreaded and changed bobbin nothing helps what am I doing wrong?
not sure if this will help you...Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimesthread buching can be caused by something as simple as the tension dial being inadvertently turned.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC ? ' eBay
www.ebay.co.uk/gds/WHY-IS-THREAD-BUNCHING-UNDERNEATH-MY.../g.html..
or you could go to this link and see if it helps you out.. thread keeps looping Google Search
Oct 22, 2017 | Sewing Machines
I am a new sewer have a Brither BM-2600 what numbers on the dial do I have for just plain stitching I have tried lots of combinations but the cotton underneath is all bunching up and not sewing right
I am not sure as to your machine, are you saying a "brother" machine? If your tension is set, say on 6 and it is too tight, turn the dial one more number......to a 7 or to a five and then check again. Also, I would rethread the machine and also take the bobbin out and then put it back into the machine. A lot of times, the bobbin isn't threaded into the machine correctly and it bunches up. Also, you can't use certain thick thread on some machines.
Jun 05, 2017 | Sewing Machines
I checked my thread and bobbin watch the video and my machine keep bunches the bottom stitch
Is it really the bobbin thread that is bunching? Generally, thread messes under the fabric are the fault of the top thread, and thread messes on top of the fabric are a bobbin problem.
Top thread bunching under the fabric is called "thread nesting" or "bird nesting" but I prefer to call it thread "barfs." Most often, it occurs because the top thread has not been seated completely in the tension disk.
Install a brand new needle.
Remove the top thread from the machine.
RAISE the presser foot and rethread the top thread.
(Verify the thread path is correct.)
Set the top tension disk at the midway point.
Retest your machine. Tweak the top tension if required.
Mar 27, 2017 | Sewing Machines
When I sew I have thread bunching up underneath the fabric, I've changed needle size, thread, bobbins and cleaned out around the bobbin holder. I'm frustrated and out of ideas.
Susan--
Easy peasy, once you know the problem and how to fix it. It's called "bird nesting" or "thread nesting" or what I refer to as thread "barfs."
Remove all the thread from the machine.
**ALWAYS RAISE** the presser foot and rethread the top thread.
Verify the top thread path is correct.
Install and thread the bobbin case, make sure it is correct.
Set the top tension to the midway point.
Now retest your machine. Birds nests gone? You may need to tweak the top tension because the factory standard changes due to age and use.
FWIW, problems appearing under the fabric are an issue of the top thread. Thread problems appearing on top of the fabric is a bobbin issue.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Mar 25, 2017 | Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
Thread on my consew 225 keeps balling the thread on the bottbottom
Sounds like bird nesting. The upper thread accumulates under the fabric creating a series of loops and knots.
First: Install a brand new needle and make sure it is installed facing the correct direction. (A new needle is the least expensive fix for most sewing machine issues.)
Second: Remove the thread. RAISE the presser foot and rethread from the beginning. Make sure it is threaded correctly (consult the owner's manual).
Third: Pull up the bobbin thread through the fabric and gently hold the thread tails in your left hand while slowly taking the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Sewing Machine Thread Bunching Up Here Why
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
Why Do Get Bunched Up Thread Under My Fabric
Feb 06, 2016 | Consew Sewing Machines
Thread is getting bunched up in machine
First thing: install a brand new needle.
Second: remove upper thread. RAISE the presser foot and rethread from the beginning. Set upper tension to the midway point between high & low numbers.
These links may be helpful:
5 Common Causes of Birdnests
Feb 04, 2016 | Sewing Machines
Cotton is loose/looping under material?
The #1 thing is to install a brand new needle (old, worn, nicked, or bent needles can create a lot of havoc).
Remove all the thread from the machine. RAISE the presser foot and rethread from the beginning verifying that it is threaded correctly. Make sure the bobbin is loaded and threaded in the bobbin case properly.
8 Tips to Fix Birdnesting in Embroidery
Jan 28, 2016 | Sewing Machines
Im using a singer 57815. Im having a problem with the thread bunching up at the underside of the fabric. Its not the bobbin thread that's binding but the top thread is bunching and getting stuck...
Hello
Reduce the thread tension to a lower number,Select a larger size needle,Remove and reinsert a new needle, flat side toward the back of the machine
Aug 02, 2011 | Singer 57815 Mechanical Sewing Machine
Bobbin thread bunching
Check between the tension disc, sometimes you can get a piece of thread caught in that and it prevents it from tightening down and making a good stitch. Also, make sure that your presser foot is in the up position when you thread your machine.
Feb 10, 2009 | Kenmore 15516 Mechanical Sewing Machine
Kenmore 15516 Mechanical Sewing Machine Logo
812 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
