Question about Uniden 5.8GHz Dual Cordless Phone
Uniden 5.8GHz and model DSS7915 have a problem
I don't know what to do with my Uniden 5.8GHz and model DSS7915 have a problem.
On the monitor both of them says """"Place Handset on main base to register""" So i have no idea what to do with it????
Can you please help me to sort this problem. Thank you.
You can contact me at 021647061
    Problem Solver:
  • 16 Answers
What that means is after you plug in the base set the #1 handset into the base charger for a few seconds, then put #2 handset into the base charger that registers it to that base at your house. continue on through the rest of them if you have more than 2 , They only need to be in the base for about ten seconds, then it should or might say registered on the screen,,Good Luck
Posted on Feb 15, 2009
CAN NOT CLEAR WATER PROOF DECT 6.0 PHONE TO REGISTER IT SAYS TO PUT ON BASE BUT I WANT TO REGISTER ON MY OTHER UNIDEN BASE BUT PHONE WON'T FIT ON BASE
Not stating the model number of your phone makes it a bit difficult because the process is not the same on all models. I am going to deal with the cordless main base only Remove any handset from the main base cradle. Then
On the waterproof handset Press and Hold the # sign until the Registering handset option shows then release it.Then on the main base, Press and Hold the FIND hs or Find or locator button for 5 seconds ( if there is no IN USE light on the base) or until the IN USE light come on, then release it. Hold the handset near the base and it will register.
Please note the Uniden waterproof handset could be a bit tricky to register and not knowing the model makes it more difficult. and you may have to apply other methods.
May 03, 2017 | Uniden Lands Phones
Put a new battery in my phone, now it gives me an out of rane message. how do I fix this?
I don't know what model it is but try these:
1. Check the main base is powered up!
2.Take out the battery again and edit a few mins and return it. Place the handset on the base. Now try.
3. If that didn't work you are probably going to to reassign the handset to the base. Check your manual on how to do that.
Nov 05, 2014 | Uniden Cordless Phone
Handsets do not register
Press the END button to exit or erase the message. Press Menu/Select. Scroll uo or down to find Register Base. Select the option, select it and put the handset in the charging cradle of the base. A confirmation beep will sound.
Jan 11, 2010 | Uniden DECT 6.0 Cordless Telephone...
Can't talk on both phone at same time. second on is always dead.
The DXI4286-2 is an Analog phone, it does not allow for both handset to be used at the same time. You can transfer a call from one handset to another, but cannot talk on both at the same time.
The following is from the user's manual for your phone:
Unavailable message is displayed
on the LCD screen of the
handset.
• Make sure the other handset is not already in use. Both handsets cannot be in talk mode at the
same time.
• Place the handset in the main base for at least 5 seconds to re-register to the main base.
• Make sure the handset is not too far from the main base when trying to use.
You might want to try one of the DECT or a Digital 2.4 or 5.8 GHz phones, they allow you to use multiple handsets at the same time.
Apr 04, 2009 | Uniden Cordless Phone
Uniden Have problem
Dear....Fixya Team,
I'm Soontaree. Thank you for your reply email. I would like to let you know i'm already solved this problem. I just have a look from the Uniden Manual so i just follow them detail like as below,
Thank you for your help i will contact to you later if i have anything problem.
Have a great day.
Soontaree
Registering DSS7905 Accessory Handsets
Your phone supports a total of ten (10) cordless handsets. Handset(s) supplied in the box with the phone base are
pre-registered at the factory. If you purchase an accessory handset, you need to register the handset before use.
Only one handset can be registered at a time. When charged, pre-registered handsets display a handset ID number.
Handsets that have not been registered display.
Before registering the DSS7905 accessory handset, the battery pack MUST be charged for 15-20 hours.
To register the DSS7905 handset:
Place the handset in the telephone base charging cradle to begin registration.
During the registration process, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
COMPLETE. is displayed; the handset has been registered to the base. If REGISTRATION FAILED. appears,
please try these steps again. When you register an accessory handset to the base, the handset ID will be
assigned.
Note:
If an accessory handset has ever been registered to a base, you must reset the handset before you can
register it to a new base. See Resetting the Handsets on page 24.
Feb 10, 2009 | Uniden TRU9480 Cordless Telephone
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
Ge edge model 25951ee3
I don't know where a manual can be found, but I know you need to place each handset in the main cradle / base station for at least 20 seconds for the handset to get Registered to that base station.
Dec 25, 2007 | Uniden Cordless Phone
Register 2nd phone
Place handset on main base station for 20 seconds.
Sep 11, 2007 | Uniden Cordless Phone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Uniden 5.8GHz Dual Cordless Phone Logo
222 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
