Hp w2408h hdmi screen won't turn back on
We had a black out and now my hp w2408h hdmi screen won't turn back on, everything else printer,pc etc turned back on.
  • 1 more comment
  • Anonymous Feb 15, 2009
    Hp w2408 LCD manufacture date 2007
    Came home one day, power was off on monitor every thing else works
    monitor won't power on again.
  • Anonymous Apr 05, 2009
    Same thing, flash of lights , everything else works, no power to the exact same monitor...... did you get yours repaired?
  • Anonymous Apr 23, 2009
    yeah it seems like every time I touch it, it turned off. And then come back on about 20 seconds later. Now i tried to show the 90 degee turn and went completely off. I just got it 2 days ago!! WTF!?
3 Suggested Answers
ejkudelka
  • 1188 Answers
SOURCE: HP screen - USB ports on screen not working
Did they ever work or is it new? You need to connect the USB hub to a USB port on the computer.
Take a look at this, figure 13 shows how it is to be connected:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065974&tmp_track_link=ot_recdoc/c01097300/en_de/c01065974/loc:1&lc=en&dlc=en&cc=de&product=3440923
click that link or copy and paste it into your browser.
EJ
Posted on Apr 10, 2010
budmrtn
  • 11361 Answers
SOURCE: We had a black and now the monitor won't turn
It may have blown fuse, it should be located close to where the AC power goes into the monitor, look for part with Fxxx labelling.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 01, 2010
Hp w2408h monitor flashing red green black blue white
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 10, 2014 | HP W2408H 24-inch Widescreen LCD Monitor
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
Hp pavillion dv9815 won't start. it just reboots over and over. shutting down each time.
take out the battery, then take out the memory. Put one of the two memory modules back in, and turn it on. If everything looks ok, shut down and put the other one back and try again...if everything is ok...then ok. If it doesn't work after the first one, let me know...
Jun 11, 2012 | HP Computers & Internet
My printer won't turn on. I have tried turning everything off and back on but it still won't turn on.
There is only one way to find out if it is an issue with the printer or the Power cord or Power Adapter.
Normally every HP printer has 2 parts. One cord connects the Printer to an Adapter. the Adapter cord then connects to the Wall outlet.
Now that you have connected the printer to working outlet, Check after 10-15 mins if the Adapter ( black box ) is warm or cold. If the Adapter is warm and the green LED light on adapter is glowing, then it could an issue with the Cord or the Printer.
Try with another Adapter or power cord to diagnose.
For Other brand printers, there should be a power adapter ( black box ) and it should be warm when connected to wall outlet, if it is not warm then it is defective power adapter that you need to replaced. Else it is a problem with printer mechanism.
Regards,
Shawn
May 07, 2011 | Office Equipment & Supplies
Linking hp pc (windows vista) with philips lcd via a hdmi and dvi cable. When computer turned on and tv uned into hdmi channel i can view windows loading but screen goes black when it has loaded and screen...
You need to set your system to output to the port the TV is on.
If it is a laptop, there is an F key to change from LCD to LCD+VIDEO to VIDEO.
If it is a desktop you need to go into your display settings (control panel or rt clk desktop/properties or whatever system you have).
May 16, 2010 | HP Pavillion s7420n PC Desktop
Hp psc 1210xi all in one printer says refilled cartridge is defective. HP says printer remembers cartridge serial number, counts number of prints executed & after certain number of prints, won't...
Well, if the electronic circuit on the cartridge has blown, you have no other alternative then to buy a new cartridge. You can remove the cartridge and gently wipe the cartridge contacts. Turn off your printer, wait for a few min, then turn it back on. Put the cartridge back.
If that doesn't work,
  1. Open the cartridge access door.
  2. Remove either cartridge (not both).
  3. Close the cartridge access door.
    • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
    • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed ), then the cartridge you have removed is the problem cartridge.
There is a cmos battery in the printer, and, yes, when you remove it, the printer forgets everything (serial number, number of copies, etc). I have found a clip, but it says it only works for some HP printers. You can try that, but I am not sure that will help solve your problem.
Jan 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
I turned on my hp dx 2450 pc and the screen said ''no signal input'' why?
Well, make sure the screen is connected to your graphics card (via VGA, HDMI, etc). If it is and there is still no signal, check to see if your computer is making the usual boot noises, beeping, fans turning on, etc. If it turns on normally, it is most likely your graphics card (if you have a separate one) or your motherboard if it has built in graphics.
Good luck, contact me if you need more help.
Dec 29, 2009 | HP Compaq dx2450 Microtower - KR611UTABA ...
Monitor comes on momentarilly, then screen turns black. when power is turned off and back on again, screen comes on for a second, then goes black again. Is this a bad monitor?
The only problem that causes the power on and off is a bad power supply. Go onto http://www.ebay.com and search for the monitor (power supply). My dad's old LCD screen had a bad power supply, but I found my old printer power cable (HP PSC 750 All-in-One Printer), and the monitor turned on successfully. It's not a bad monitor, unless the PSU hookup is like the PC ATX/Baby-AT PSU cable, then it might be the issue. Monitors before 2004 or 2005 have the ones, like the HP PSC 750 uses. The monitor is either defective, or the power supply is dead.
p.s.: check the voltage, amp usage, etc. on the PSU for the monitor for better results.
Aug 28, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Computers & Internet Logo
880 people viewed this question
David Payne
David Payne
