Question about Kenmore 15516 Mechanical Sewing Machine
Bobbin thread bunching
The thread on the underside of what I am sewing bunches up & looks like a plate of spaghetti. I have tried tightening the tension on the top thread and the bobbin (with the screw on the bobbin case). Yes - I have rethreaded the whole machine and rewound the bobbin. Help!! I am in the middle of a large curtain project!!
    Scholar:
  • 69 Answers
Check between the tension disc, sometimes you can get a piece of thread caught in that and it prevents it from tightening down and making a good stitch. Also, make sure that your presser foot is in the up position when you thread your machine.
Posted on Feb 12, 2009
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
Brother sewing machine model vx 1140
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Also could be a timing problem, and the machine would need to be checked.
Sep 08, 2013 | Sewing Machines
Thread on the bottom side of stitch is all bunched up
1. Change needle
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
Oct 09, 2012 | Sewing Machines
Bunching and Looping (Bobbin Side)
Thread the machine with different color thread for the needle and the bobbin, then see which color is bunching up.Ill bet it is the top thread.
Jun 16, 2010 | Brother CS6000i Computerized Sewing...
THREAD GET BUNCHED UP UNDERNEATH THE FABRIC, THE STICHES SEEM TO BE INCOMPLETE THE TOP LOOKS GOOD THAN I TURN IT OVER AND THE THEAD IS BUNCHED AND LONG LOOPS OF THREAD ARE LEFT. THANKS LOU
Hi Lou! This sounds like a tension problem--the tension on the top thread is too loose. Try using different color threads on the top and bobbin, then carefully rethread everything. Stitch a couple of inches and check the underside. If the top stitches look fine and the bottom ones are loose and loopy, and with the pressure foot down, tighten the tension. Move the knob or dial (whichever you have) just a little bit. Sew a couple of inches more, and recheck. Continue to sew and recheck, gradually tightening the tension, until you see little if any bobbin thread on the top or top thread on the underside of the fabric.
Let me know if this helps, ok?
Robbie
Jan 27, 2010 | Singer Sewing Machines
Wont sew thread bunches up
Hi!
I think you are threading the top of the machine incorrectly. Make sure that what I'm saying is correct, use two color threads to sew with- and you will see that it is in fact the top thread that is bunching.
This might be a tension problem. Could be the bobbin is not threaded in the case right. First, check the threading of the bobbin and then check the stitch.
Next, adjust the tension on the bobbin case. There is usually a small screw on the case that can be tightened or loosened. I think you may need to adjust it a bit or adjust the top tension knob, just a small bit at a time. It the top does not change the stitch, then go to the bobbin case and adjust the screw to tighten the stitch a little bit more.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 19, 2009 | Kenmore Sewing Machines
Thread is bunching underneath fabric
Needle in correct? Be sure your bobbin is not in upside down and turning the wrong way. Possibly the hook that the bobbicase fits in/on has been hit by a needle and caused a burr that is catching the thread as it comes around. The burr would have to be polished off or hook replaced. The machine could be slightly out of time also.
Feb 10, 2009 | Kenmore 15516 Mechanical Sewing Machine
Bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Jan 23, 2009 | Husqvarna Viking 1
I have a White 3300 embroidery machine not catching bobbin thread
Try putting a new sewing machine needle in and make sure the eye of the needle is facing the right way. Needles look like they should go just anyway, but if they aren't in right, it could cause the problem you are having.
Jan 01, 2009 | Brother LS-2125 Mechanical Sewing Machine
Kenmore 15516 Mechanical Sewing Machine Logo
401 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
