Question about E-Machines eMachines Desktop PC
WZC for Wireless (ZyXel)
I am trying to set up a verizon wireless internet connection using Zyxel. I installed the software but can't set up the connection. Keep geeting "use WZC" to run program. Where do I get information for this component. I have e-machine mod# T2798 using windows XP.
ty
    Genius:
  • 1,605 Answers
1. Click Start and Run
2. Type into the Run box "services.msc" (without the quotation).
3. Scroll down and look for the service Wireless Zero Configuration
Double Click on the Service, Screen Shot of the services
4. Make sure that it is Started and that the startup type is set to automatic.
Screen Shot of WZC
If the Service did not Started, or and is Not set to Automatic.
To Start the Service click on the Start button.
To set the service to automatic, click on the down arrow and change it to Automatic
Posted on Feb 10, 2009
I have EarthLink Internet is a zyxel p-600 can I connect a wireless router? And if yes what kind should I buy or can it be any wireless router?
If I read this correctly the Zyxel P600 is a wireless device? Take a look at this, is this your device: https://www.magnet.ie/wp-content/uploads/2012/01/ZYXEL-install-and-wireless-set-up.pdf OR HERE: http://www.zyxel.com/products_services/p_660h_series.shtml?t=p You can add a second wireless device, if you want, by using a port on the P600, is that what you are asking? Depending on what you want to connect, the wireless adapter specs, to the wireless? B, G, N, AC wireless?
Apr 13, 2013 | Computers & Internet
Limited or no connectivity using a ZyXel adapter on Windows XP
Start -> Run
Type in services.msc
Click the OK button, which will bring up the following dialogue.
You may want to maximise the screen. Scroll down to Wireless Zero Configuration and select it.You now have the option to Start the service.You also need to change the Startup Type from Manual to Automatic.Action -> Properties->Click OK.
Apr 06, 2012 | Zyxel ZyAIR G-220 (ZYAIRG220) 802.11g/b...
I dont have the installation disc to install zyxel G-220 v3 wireless USB drive onto my computer, and I can not find it on the zyxel's support and download library. where can I find this software online and...
You can download the software from http://verizon.net/zyxel There are 3 folders, one for Windows XP, one Windows Vista, and one for Windows 7. You can extract the folder you need for the version of Windows you have. Then you can use the Found New Hardware Wizard to install the drivers.
Jan 21, 2011 | Zyxel G-220 802.11g/b Wireless Adapter
I currently am using a Zyxel G 220v 3 wireless adapter - I believe all components are configured correctly (nothing comes up in a list of items that needs to be configured on my computer) - one of the...
I'm NOT a Windows guru, but I think this is an issue with Windows, not your Zyxel driver.
There is a setting somewhere in the network area of Windows that tells it to automatically connect to a known favorite network if that network appears. I suspect you just have to find that setting, turn it on, and make sure the network you use is in your list of favorites.
Jul 13, 2010 | Zyxel G-220 802.11g/b Wireless Adapter
Cable Network Routing with Zyxel 600
You have to set different ip address. To clear this up this how I got my setup. I have verizon internet. I use a westell 6100g modem, I have the local ip address set for 192.168.1.1 and I got a linksys wireless router and the ip address set for 192.168.9.1. Then I plug my modem into the wan port and it works. What am I doing is setting a static ip address from my modem to the router and using the router to distribute my address through the network. If you have any printers on the network you need to change that numter to 192.168.9.x number. If you don't have two different numbers set the router will take over.
Aug 09, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
P660HW-D1 Router not working wireless
Problem with the Zyxel P-660?   I experienced:
1. laptop would see the wireless 660HW briefly and then it would disappear.   2. laptop would not see wireless at all. 3.  same issue with desktop when using USB wireless 11g dongle 4. no problem on wired connection (ethernet)
EASY solution!   if Zyxel is set to scan for a channel it will want to work on channel 13 nearly every time in a busy environment.
HP laptops and many receivers cannot recieve on 13 -  highest channel is 12.
Pick on setting for the Zyxel which matches an available channel on your receiver.  Problem solved.
Nov 20, 2008 | Zyxel P660HW-D1 Router
Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
ciao
Nov 10, 2008 | Zyxel Prestige 334 Router
Setting up a zyxel router
Do you have a wireless card on the PC's and a wireless router connected to Comcast Broadband. If so read the Zyxel manual. It should have some straightforward instruction. Use DHCP.
Aug 26, 2008 | Zyxel Prestige P-330W Wireless Router...
Connecting using wireless
because of zyxel support only zyxel product only
Apr 03, 2008 | Zyxel Prestige 660R Router (91004397002)
Zyxel p660hw and g202 problem
I had an almost identical problem and contacted Tech support at Zyxel. They were excellent and the guy talked me through to a solution. The main issue related to 'Bandwith management' which defaults to active on the router configuration. Unset all three (Wan, Lan, Wlan) and see if it sorts out problem. Because of some other issues I did have to reset the router to start with and on the wireless client I unset 'Obtain IP address automatically' and used an IP address with the default gateway set to the router address. If this does not help, I would recommend talking to Zyxel Tech Support, the consultant I spoke to was brilliant.
Nov 22, 2007 | Zyxel P660HW-D1 Router
E-Machines eMachines Desktop PC Logo
104 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
