I am re-posting my problem because I REALLY need some advise! I work at home and NEED my computer to run right or I can't work. Everything on my screen is HUGE. I am unable to change the display settings and resolution. All the options except 2 and 16 colors have vanished! The slider will not work. ANY input would be GREATLY appreciated!
Show your appreciation by commenting on Please help! Display settings !!:
Solution #3
posted on Aug 01, 2007
Joey2 - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
This is the report I ran from Aida. THANK YOU!!
AIDA32 ?? 1995-2004 Tamas Miklos
Version AIDA32 v3.93 Author Homepage # Report Type Report Wizard Computer MY COMPUTER (MY COMPUTER) Generator Mitzi Operating System Microsoft Windows 98 SE 4.10.2222A (Win98 SE) Date 2004-07-10 Time 19:51
Summary
Computer: Operating System Microsoft Windows 98 SE OS Service Pack None Internet Explorer 6.0.2800.1106 (IE 6.0 SP1) Computer Name MY COMPUTER (MY COMPUTER) User Name Mitzi
Motherboard: CPU Type AMD K6-2, 350 MHz (3.5 x 100) Motherboard Name ECS P5MVP3-AT Motherboard Chipset VIA VT82C598 Apollo MVP3 System Memory 128 MB (SDRAM) BIOS Type Award Modular (06/30/98) Communication Port Communications Port (COM1) Communication Port Communications Port (COM2) Communication Port Printer Port (LPT1)
Display: Video Adapter Standard PCI Graphics Adapter (VGA) 3D Accelerator SiS 86C326 Monitor NEC MultiSync 75 (1Y15974TA)
Multimedia: Audio Adapter Microsoft Windows Sound System Audio Adapter Sound Blaster 2.0
Storage: Floppy Drive GENERIC NEC FLOPPY DISK Disk Drive GENERIC IDE DISK TYPE46 Optical Drive LG CD-ROM CRD-8400B (40x CD-ROM)
Partitions: C: (FAT32) 19444 MB (16411 MB free)
Input: Keyboard Standard 101/102-Key or Microsoft Natural Keyboard Mouse PS/2 Compatible Mouse Port
Network: Primary IP Address 192.168.1.33 Primary MAC Address 44-45-53-54-00-00 Network Adapter PPP Adapter. Network Adapter Realtek 8139-series PCI NIC (192.168.1.33) Modem Standard Modem
DMI
[ BIOS ]
BIOS Properties: Size 64 KB Boot Devices Floppy Disk, Hard Disk Capabilities Unknown Supported Standards DMI Expansion Capabilities Unknown
[ System ]
System Properties: Manufacturer VIA Technologies, Inc. Product VT82C597
Processor Properties: Manufacturer AMD Version AMD-K6 External Clock 100 MHz Current Clock 350 MHz Type Central Processor Voltage 3.3 V Status Enabled Upgrade ZIF Socket Designation Socket 7
[ Caches / Internal Cache ]
Cache Properties: Type Internal Status Enabled Operational Mode Write-Back Maximum Size 64 KB Installed Size 64 KB Supported SRAM Type Synchronous Current SRAM Type Synchronous Socket Designation Internal Cache
[ Caches / External Cache ]
Cache Properties: Type External Status Enabled Operational Mode Write-Through Maximum Size 2048 KB Installed Size 512 KB Supported SRAM Type Synchronous Current SRAM Type Synchronous Socket Designation External Cache
[ Memory Modules / BANK_1 ]
Memory Module Properties: Socket Designation BANK_1 Type FPM Speed 70 ns Installed Size Not Installed Enabled Size Not Installed
[ Memory Modules / BANK_2 ]
Memory Module Properties: Socket Designation BANK_2 Type FPM Speed 70 ns Installed Size Not Installed Enabled Size Not Installed
[ Memory Modules / BANK_3 ]
Memory Module Properties: Socket Designation BANK_3 Type FPM Speed 70 ns Installed Size Not Installed Enabled Size Not Installed
Memory Module Properties: Socket Designation BANK_5 Type DIMM, SDRAM Speed 70 ns Installed Size Not Installed Enabled Size Not Installed
[ System Slots / ISA ]
System Slot Properties: Slot Designation ISA Type ISA Data Bus Width 16-bit Length Long
[ System Slots / PCI ]
System Slot Properties: Slot Designation PCI Type PCI Usage In Use Data Bus Width 32-bit Length Long
System Slot Properties: Slot Designation PCI Type PCI Usage Empty Data Bus Width 32-bit Length Long
[ Port Connectors / PRIMARY IDE ]
Port Connector Properties: Internal Reference Designator PRIMARY IDE Internal Connector Type On-Board IDE External Connector Type None
[ Port Connectors / SECONDARY IDE ]
Port Connector Properties: Internal Reference Designator SECONDARY IDE Internal Connector Type On-Board IDE External Connector Type None
[ Port Connectors / FDD ]
Port Connector Properties: Port Type 8251 FIFO Compatible Internal Reference Designator FDD Internal Connector Type On-Board Floppy External Connector Type None
[ Port Connectors / COM1 ]
Port Connector Properties: Port Type Serial Port 16450 Compatible Internal Reference Designator COM1 Internal Connector Type 9 Pin Dual Inline (pin 10 cut) External Connector Type DB-9 pin male
[ Port Connectors / COM2 ]
Port Connector Properties: Port Type Serial Port 16450 Compatible Internal Reference Designator COM2 Internal Connector Type 9 Pin Dual Inline (pin 10 cut) External Connector Type DB-9 pin male
[ Port Connectors / LPT1 ]
Port Connector Properties: Port Type Parallel Port ECP/EPP Internal Reference Designator LPT1 Internal Connector Type DB-25 pin female External Connector Type DB-25 pin female
[ Port Connectors / Keyboard ]
Port Connector Properties: Port Type Keyboard Port Internal Reference Designator Keyboard External Connector Type PS/2
[ Port Connectors / Detected ]
Port Connector Properties: Port Type Mouse Port Internal Reference Designator PS/2 Mouse Internal Connector Type PS/2 External Reference Designator Detected External Connector Type PS/2
[ Port Connectors / USB ]
Port Connector Properties: Port Type USB Internal Reference Designator USB Internal Connector Type None
CPU
CPU Properties: CPU Type AMD K6-2, 350 MHz (3.5 x 100) CPU Alias Chomper Extended, K6-2-CXT CPU Stepping CXT/A L1 Code Cache 32 KB L1 Data Cache 32 KB L2 Cache 0
CPU Physical Info: Package Type 321 Pin PGA Package Size 4.95 cm x 4.95 cm Transistors 9.3 million Process Technology 5Mi, 0.25 um, CMOS Die Size 81 mm2 Core Voltage 2.2 - 2.4 V I/O Voltage 3.3 V Typical Power 8.1 - 17.8 W (depending on clock speed) Maximum Power 13.5 - 29.6 W (depending on clock speed)
CPU Manufacturer: Company Name Advanced Micro Devices, Inc. Product Information # en/Processors/ProductInformation/0,,30_118,00.html
CPU Utilization: CPU #1 100 %
Problems & Suggestions: Problem No CPU L2 cache found. This may cause performance penalty.
CPUID
CPUID Properties: CPUID Manufacturer AuthenticAMD CPUID CPU Name AMD-K6(tm) 3D processor CPUID Revision 058Ch Extended CPUID Revision 068Ch Platform ID C8h (Socket 7) IA CPU Serial Number Unknown
Instruction Set: AMD 3DNow! Supported AMD 3DNow! Professional Not Supported AMD Enhanced 3DNow! Not Supported AMD Extended MMX Not Supported AMD64 Not Supported Cyrix Extended MMX Not Supported IA-64 Not Supported IA MMX Supported IA SSE Not Supported IA SSE 2 Not Supported IA SSE 3 Not Supported CLFLUSH ... read more »
Was this solution helpful? Show your Appreciation by rating it:
Solution #5
lawyer - usenet poster
I have looked every where for the mfg of the video card, to no avail. All I can come up with is Standard PCI Graphics adapter (VGA)...?? I ran Aida32 and have all sorts of info about my system but don't have any idea what to do now. (???) Thank you for replying!
manufactures web site,
Solution #6
Hart - usenet poster
Hi Mitzi,
This usually indicates that there is an incorrect video driver installed. Here's some information on replacing the video driver.
Tip: Go to Start - Run and type Msconfig and press enter. On the General Tab click advanced, and make sure "VGA 640x480x16 is NOT checked before continuing.
To correct this you will first have to identify the video card installed. That may include checking documentation, contacting the system manufacturer, or opening the box and looking for identifying marks on a video card or video chip on the mother board. Some systems will display the Video Adapter information on the top of the screen when the system first boots up. Some manufacturers displays a logo screen that may cover this information. It may be able to be removed temporarily by pressing the ESC key when the logo first appears. Once the Video card has been identified, go to the manufactures web site, download and install the latest video driver and install it as per there instructions. Or the system may have shipped with a video card driver it can also be used.
-- Regards, Bert Kinney [MS-MVP DTS] # How to Configure Outlook Express for Internet News: #
