Question about Numark TT1520 Turntable
Volume is low on my turntable
I just hooked up my turntable and everything is attached correctly but the sound is really low even with my stereo volume maxed out. How can i fix this?
  • 46 Answers
You have to amplify the output from your turntable output to the input of your amplifier. To do this you can buy what is known as a pre-amp. Radio shack probably still sells them.
Be sure to ground your turntable to your amplifier and not the pre-amp. This should stop any hum or at least diminish it. Bear in mind that your records will not sound as loud as your CD's. Hope this helps.
Posted on Feb 10, 2009
Low volume on my technics turntable compared to other appliances
it needs a pre amp, or special phono input that will boost the signal, those old turntables have very low output lvl
Mar 07, 2013 | Audio Players & Recorders
Purchased stanton T.52 Turntable. hooked it up to stereo but volume is very very low. cannot find line / phono switch if there is one on this model.
The only output from the turntable is the low-level signal from the cartridge. Most likely, the receiver you've hooked it to doesn't have a phono input. Many receivers today don't come with one, and if you connect the turntable to a line-level input you get either very low volume or none at all, depending on the cartridge. What you'll need is a turntable preamp to boost the output to line level so the receiver will work properly. Radio Shack still carries a preamp, available online and in some stores. You can also find preamps online (here's one at Amazon). With the preamp connected you can use any free input on the receiver.
Jun 05, 2011 | Stanton T52 Turntable
I have hooked my turntable up to my stereo and even at full volume its extreamly quiet, is there a problem or is this stereo just not set to play records? do i need some sort os amplifier?
Hi, Remove the rubber mat on the platter, there is a toggle-switch for the pre-amp. With the power off, manually rotate the platter and it will become visible through the gaps. This should resolve the low volume issue. Hope this helps. Post back with your results and good luck.
Feb 01, 2011 | Sony PS-LX250H Turntable
How do I hook up a home theater system to my sansui record player? DO I need any special hook up? Where is the volume controlled?
Some make and model numbers would have helped.
A traditional turntable requires a preamp inline with it to PRE amplify and frequency-balance (*) the minute signal produced by it's cartridge. Most stereo receivers and preamps have Phono connections and internal preamplification strictly for that purpose. Lacking a Phono Preamp you will have unusuable very low, tinny sound.
* Google "riaa equalization" for some background
Some of the newer turntables come with selectable internal preamplification to solve the lack of it in modern equipment.
Volume is always handled at the electronics.
Jan 30, 2011 | Audio Players & Recorders
I just hooked up my husband's turntable to our stereo receiver and the volume is very low. Is that inherent in the unit, or am I missing something?
You need to make sure that you plug it into the receiver with PHONO input.
New receivers today does not have PHONO stage so the sound will be very very low and not listenable at all.
what model is your receiver?
Jun 18, 2010 | Sony PS-LX300USB Turntable
Volume Level on Memorex 9299M 4-in-1 Turntable System Way Too Low
It's the nature of the all-in-one turntable beast to be low fi and low performance. Too much volume and vibration would feed back through the turntable.
It does have a Line Out that you could slave over to REAL electronics and speakers.
May 23, 2010 | Memorex Nostalgia Turntable and Stereo...
Insignia stereo reciever inputs stopped working
check a button on the front labeled 'straight' or 'direct'
Nov 02, 2009 | Insignia 200W Stereo Receiver
Home theater hooked up volume sounds low
Check your different settings either in your t.v. or your amp. In your menu settings you can change your audio. Bass trebile etc. and even sometimes switching it from stereo,mono, dolby digital will increase your volume. Dolby digital is very quiet if your not running and exteranal amp system. so try changing it to stereo and your volume should increase.
Aug 31, 2009 | Panasonic Audio Players & Recorders
Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Mar 02, 2008 | Audio Players & Recorders
I want to copy some records on CDR but the sound is too low. Can someone help?
If you have and amplifier or reciever you can frist plug your turntable into the amp or rec. and then to your sony CD recorder and then you should be able to adjust your volume to a higher position, also you can hook up and Equalizer and get the needle sound completely out unless your old school and like that LOL. There is also another way to save and make copies of all your old and new records By using the computer and getting a good sound card for your computer unless you have a good one or even buy a expansion bay with remote control made also by sony you can digatally remake all of you albums, Well sorry to go on and on but I am really into doing the same thing , If you need anymore help Please Let Me know Thanks again bear001
Dec 12, 2007 | Sony PS-LX250H Turntable
Numark TT1520 Turntable Logo
1,007 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
