Question about Wacom Intuos2 6 x 8 10-Pack (XD68USBAC10PACK)
My wacom is plugged in, but it's not working.
It worked fine for about a year, but suddenly one day when i plugged it in i had to work with the cord to get the light to come on. Now it wont light up at all.
  • 1 more comment
  • hobomaster Feb 11, 2009
    it's a usb with a cord. it was usually around the USB that i had to fiddle around with. it is attached at both sides
  • Evol Genius
    Evol Genius May 11, 2010
    Which port do you need to fiddle with? Do you need to wiggle the end by the tablet or the compuer? If it's he computer do you have problems with any other USB devices and that port?
  • Evol Genius
    Which end of the cord? The end to the tablet, or the end going to your computer? Also, is it USB and if so is one end built into the graphics tablet or are both detachable?
5 Suggested Answers
The Machine
  • 788 Answers
SOURCE: Wacom tablet stopped working, blue light on.
If you are using a Dell with Vista on it you can't use Mac )SX drivers. Get the Vista driver from here for the Intuos3: ftp://198.145.255.42/drivers/IBMPC/pro/WacomTablet_605-7.exe
Posted on Apr 10, 2008
SOURCE: Wacom pen does not function
Unfortunately I had the same problem.
Its from moisture in the pen, could be from humidity or something spilling on it. Try searching google for information on how to fix wet electronics. (Im quite sure youre not supposed to use heat)
Posted on Sep 17, 2009
bunnydawg
  • 5158 Answers
SOURCE: My computer suddenly won't recognize
i would suggest reinstalling the software that comes with the graphics table as this should also include any drivers. i presume you have tried the device on more then one usb port on your computer as well.
what operating system are you using ?
Posted on Dec 07, 2009
Make sure driver is installed and there is not any ? mark or yellow ! mark in device manager.
Reinstall your tablet driver then check.
Uninstall all usb driver from computer.
Connect your tablet to computer then when you power up the computer press F8 key then enter in safe mode.
Make sure usb cable is works fine if you connect your tablet to computer with usb cable.
Let me know if you need further assistance.
Thanks for using FixYa.
  • 6 Answers
SOURCE: My wacom tablet has loses connection
You should get the tablet, and then get some tape, and then move around the wire, and then when it turns on, tape it onto the tablet, and then it should work intill you take off the tape.
Posted on May 05, 2010
Testimonial: "Thank you! Since posting I had determined that it was a wire placement issue and I have been managing. But, I will definitely tape it and see how that goes!"
Since you are running Windows Vista on your PC this is the driver you should have downloaded.
Click Here
Serial cables are not hot swappable. The computer and tablet should be turned off before you plug them in.
Apr 10, 2008 | Wacom (PTZ930AC) Graphic Tablet
Apr 28, 2010 | Wacom (PTZ930AC) Graphic Tablet
My computer suddenly won't recognize my wacom tablet--the blue power light doesn't even flash when I plug it in. I think it's a problem with my computer rather than my actual tablet, as the tablet...
Dec 07, 2009 | Wacom Computers & Internet
Sep 16, 2009 | Wacom (EP130EPE) Digital Pen
Wacom Cintiq won't turn on
Hi Joni Lu: I had the exact same problem with my Cintiq 21 UX. Mine is similarly, about 5 years old. I called every where looking for an authorized or unauthorized repair shop... but to no avail. I finally called Wacom tech support and they told me the unit had to be shipped to Vancouver Washington to be repaired in a "clean" room because of dust. Knowing the expense that would incur (I'm in Toronto Canada), I deliberated for a few days before deciding to open it myself. The reasoning being I could see the back of the power button plate through the air vents in the back. I don't think the power button assembly was part of the sealed screen assembly. First I made sure it was unplugged. Then I lay it flat on it's front and took off all the screws. There's a copper foil that covers the back of the power button and screen controls assembly. After lifting it off I jiggled the wires, unplugged and plugged the wire connectors for the power button and the screen control sections and made sure all the screws were tightened. After replacing the back and plugging the power plug in, I tested the power button... and LO AND BEHOLD it worked perfectly!! Cross my fingers, it's been an hour now it's still working. I think I may have saved myself 3 grande by taking this initiative. Hopefully this helps Joni_Lu.
May 16, 2009 | Wacom Cintiq 21UX (CINTIQ21UXNR)
Bamboo Fun usb device not recognized
Change the USB cable... this is the problem...
Sep 22, 2008 | Wacom Bamboo Fun USB Tablet with Cordless...
Wacom Intuos 3 on Leopard No Longer Working
I had the same problem. Repairing permissions didn't help, but deleting old software and reinstalling new WACOM software did. Thank you, Swedey! :o)
Jul 22, 2008 | Wacom Intuos3 Graphic Tablet
Hey I had this problem too with my Bamboo too, I'm not sure if it was anything I changed or whatever but either way the blue light was on but it wasn't registering the pen.
I found a way just minutes ago to fix it however!
Go into 'start', 'all programs', then look for 'pen tablet'. Hopefully you should have this. If not then download the latest driver for your tablet from the wacom website and that should install it.
Next choose 'pen tablet preference file utilty'. Then under 'my preferences' choose to remove. Bingo! All was well in the world again.
This worked for me so hopefully it will for some of you guys too! Good luck!
Jan 15, 2008 | Wacom (PTZ930AC) Graphic Tablet
Loosing pressure sensitivity
I was trying also, didn't work at all, and I'm going to try to close and open Adobe Photoshop CS2. But I need it to work on a few adoptables! I need it NOW!
Nov 29, 2007 | Wacom (PTZ930AC) Graphic Tablet
Wacom Intuos2 6 x 8 10-Pack (XD68USBAC10PACK) Logo
89 people viewed this question
Top Wacom Computers & Internet Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
NIK
NIK
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
