Question about RCA D61W20 61" Rear Projection Television
Rca d61w20 wont come on
I could unplug it turn it on it would work for a couple minutes go back off so i kept repeating the process until i seen a flash of light and now nothing except the power light comes on and blinks.
  • Anonymous Feb 22, 2009
    took it to repair man says i have a blown tube!! Thats all he said and it would be $675 to have fixed any ideas to what tube he is talking about and where i can find it?
  • RCA Master
  • 5,138 Answers
CK capacitors on Deflection Board cp150 2200uf 16v if puffed up on top it is bad so replace cp114 and cp120 / 220uf 325v.
Posted on Feb 10, 2009
D61w20 rca turns on and off
I have a RCA D61W20 chassis ITC222, I had the same problem and my repair guy found out the blue bulb was the main problem, along with replacing some transisters on one of the power boards, He also had to adjust the service convergence (not auto convergence). Works great now!
Aug 27, 2009 | RCA D61W20 61" Rear Projection Television
Trouble turning on RCA D61W20
the green light blinks three times but does not come on
Aug 16, 2009 | RCA D61W20 61" Rear Projection Television
Wont turn on, power light for 2-3 sec, squeals for 1 sec,
you have defective power oscillation from the inverter section..
Jul 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV shuts off on its own and wont come back on until unpluged.
On the Deflection board CK 3 capacitors cp150,cp114,cp120 If cp150 is puffed up on top it is bad 2200uf 16v /other 2 caps are 220uf 35v.Also resolder all pinns on FBT
Jan 13, 2009 | RCA D52W23 52" HDTV CRT TV
you will need a new flyback number 259296 and also a new cp150 which is a 2200uf 25V radial capacitor. You can get replacements at the following link and they provide free installation instructions.
Sep 19, 2008 | RCA D61W20 61" Rear Projection Television
RCA will not turn on
replace the flyback. you can get a replacement at the following link with free tech support to expain step by step how to replace it. you need flyback 259296 Heres the link.
Aug 11, 2008 | RCA D61W20 61" Rear Projection Television
Fault with Ariston Washer/Dryer
Make sure the filter is clean, its behind the front bottom panel which just pull off, then unscrew the filter thumb wheel until it comes out. Check it is clean and replace, Now unplug the machine and set the programme to your normal start setting leaving the door open. Remove the screws retaining the back panel and unplug all the connectors to the circuit board found in the bottom left hand corner. Turn the power back on ensuring the red LED illuminates and leave for 2 or 3 minutes before unplugging the power again and reconnecting the circuit boards and replacing the back panel. Reconnect the power and turn the machine on, close the door and with luck it will work. If this does not clear the fault repeat the process again or look on ebay for a new machine!
Oct 13, 2007 | Washing Machines
RCA D61W20 61" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
