Question about Brother MFC-5440CN All-In-One InkJet Printer
Print only black and white for brother mfc 3360c
I would like to print only black and white for a brother mfc 3360c. I only use if for faxing but it is asking me to replace the yellow cartridge. Does anyone know a way to work around this?
  • Anonymous Feb 18, 2009
    the same thing is happening to me!
Power off the printer.press menu and power on .do'nt release menu button until maintenance appear and flashes fax, scan and copy . type 10 . then next type 49. you will see 00000000.just change last 0 to 1. 00000001. press 99 to exit. you will find the printer only prints B/W only.
Posted on Sep 15, 2011
    Genius:
  • 2,120 Answers
No workaround, sorry.
Posted on Feb 11, 2009
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Black cartiage is not working
Sir,
Check the black cartridge it will refill or not? open the black cartridge and shake it and reinsert. Check with printer options, if any option selected with color only uncheck it and select the best quality option.
Thanks
Good Luck
Aug 05, 2009 | Brother MFC-3360C All-In-One InkJet...
Brother mfc3360 blank ink doesn't print
brother is good printer,there are many facitil as we can block one type colour as black or colour . look once a time in your printer option.or setting. , Is there on type colour is set only?
Jun 20, 2009 | Brother MFC-3360C All-In-One InkJet...
Have a brother mfc3360c and had to install windows xp
You do not have the right driver downloaded. I actually just had that same problem. I could print but not scan through the CC3 panel. Follow that link and download the correct driver. http://www.brother-usa.com/downloads/
Apr 15, 2009 | Brother Multi-Function Center MFC-3360c...
Printing in color
You can't. This is a Black and White laser printer. If you want to print in color, you need to buy a Color Laser printer.
Feb 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Will not print.
What a ditz, it just needed a new ink cartridge.
Jan 23, 2009 | Brother MFC-3340CN All-In-One InkJet...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
How to print with black/white only with brother MFC-3360C USB printer
Set the product software print setting to grayscale. Follow these steps to change this setting:
  1. In the software application you are trying to print from, click File , and then click Print . The Print dialog box opens.
  2. Make sure your printer is selected, then click Preferences . The printer Preferences dialog box opens.
  3. Select the Color tab, then select the Print in grayscale option.
May 06, 2008 | HP PSC 1410 All-In-One InkJet Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
318 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
