Question about Maxim Garden
Engine dies when tines are turned on and start to dig
There doesnt seem to be any thing in the careruator and the tiller runs fine until i try to till with it then it die almost immediatly. I was wondering if it could be out of oil in the chain drive and what kind of oil to use
3 Suggested Answers
  • 138 Answers
SOURCE: Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Posted on Aug 21, 2009
  • 48 Answers
SOURCE: Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Posted on Apr 16, 2010
Tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Jun 30, 2010 | Mantis 2-Cycle Tiller
Does not reve up engine with trottle cable
The troy bilt tiller is designed so that the engine revs up when the tiller starts to dig. If it is running just start tilling and the engine will rev as it needs to. If it won't start, get back as I can assist you with that.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Troy Bilt tiller dies when I engage the tines.
Bogging down may indicate debris or old gas in the carb. Try doing a carb cleaning, and add a small amount of Seafoam gas additive to your gas.
Mar 21, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
My rear tine tiller lurches out of control when I use it
Hi it sounds like you are trying too till the soil with the tiller in the fast position and probably too deep for your first pass. Really the fast position is for transporting the tiller from the field. Try putting the tiller in slow which would be the down position. Turn the throttle all the way foward, engage the tines and push your depth rod on the back down to where it is only going into the soil about four inches or even less depending on the hardnes of the soil. Even though a Troy is the best Tiller made it will try to run away with you when your trying to hog the soil all at once. Your depth setting is very important and people seem to forget the importance of adjusting it. Try these things, and remember to alway's start your tilling in the slow full throttle position. Lowering your depth a little at a time. Till you find the appropriete feed for your speed.
Jan 07, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
288 people viewed this question
Top Maxim Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Maxim Garden Expert? Answer questions, earn points and help others
