Question about Dell Inspiron 2200 Notebook
My laptop wont come on (Dell Inspiron 2200)
I think my battery still works because the light is green when I plug it in but it does not charge my laptop sooo my question is what I do from here should I take it to someone to look at it because if the battery is okay then it is the laptop that is having problems well I dont know much about computers sooo please talk in lamens term for me!!!!!!!!!!!
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Are you getting Lights on the top near the keyoard when you turn the laptop on?
  • 57 Answers
I have experinced the same issue with the Dell laptops.
My remedy was to purchase a new power supply..(This is the name of the power cord that came with your laptop). You can purchase the power cord from any computer store.
Ask he sales person if you can try the new power cord prior to leaving the store just to make sure this solution works.
I hope this solution works for you as well.
Posted on Feb 10, 2009
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Dell Inspiron E1705 battery light flashes 4 amber lights, then 1 green. The battery seems to charge.
The ambar lights are warning you the battery is becoming to dead, it means in a short time, if it has not happens now, the battery won't retain the charge anymore, it is time thinking in a replacement if you use your laptop without plug in the power outlet.
Dec 29, 2009 | Dell Inspiron E1705 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Inspiron 2200
Caps locks, num lock, battery charged, Scroll lock
Apr 13, 2009 | Dell Inspiron 2200 Notebook
Battery not charging
If the plug is not using correct current in correct location, ie plugged in backwards yes it will not charge unit properly.
Feb 09, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 won't start
First thing I would try is to unplug the machine, remove the battery and clean the contacts on the battery and in the battery housing with a pencil eraser. Blow out the shavings and reinstall battery - the way it sounds is that there may be dirt or corrosion causing an interference between the computer and battery contacts - for charging and powering up.
Feb 01, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron Battery problem
Try this trick. Remove the battery from the laptop and make sure the ac adapter is not plugged in also. Hold the power button for 30 seconds. Place the battery back in and see if it powers on. If not let me know.
Hope this helps.
Oct 29, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Sep 28, 2008 | Dell Inspiron 2200 PC Notebook
Flashing amber battery light
Sure, this just mean your are in charging mode, but your battery is at full charge. Should your battery need charging and in charging mode the lights would be green most likely.
Regards,
Worldvet
Please don't forget to rate our solutions as fixed if we answered your questions or fixed your problem.
Jul 13, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
118 people viewed this question
Alun Cox
