To program your RCA universal remote to control your Naxa DVD player ND-861, you will need to use the correct code for your device. Here are the steps to follow:
Power on your Naxa DVD player.
Press and hold the "Code Search" button on your RCA universal remote until the indicator light turns on.
Release the "Code Search" button.
Press and release the "DVD" button on your RCA remote.
Enter the code for your Naxa DVD player. You can find a list of RCA remote codes for Naxa DVD players in the RCA remote manual that came with your remote or by searching online. For example, the code for Naxa DVD players may be 3394.
Press the "Enter" button on your RCA remote. The indicator light on your remote will turn off if the code was entered correctly.
Test the remote to see if it's working. Try playing a DVD and using the remote to navigate the menu.
If the first code you tried didn't work, repeat the steps with a different code until you find one that works. If none of the codes work, it's possible that your RCA universal remote is not compatible with your Naxa DVD player.
you can just buy an Android-based phone, and download a piece of free remote control apps as well as installing it on your phones.
You can check on this: How to Play Blu-ray without Remote
In order of best to worst quality, and depending on which connectors both have.
1. Hdmi ( Video and Sound in one cable )
2. RGB also known as color stream (Red,Blue, and Green RCA ) Sound Seperate ( Red and White RCA )
3. Composite ( Yellow RCA ) Sound Seperate ( Red and White RCA ) sometimes mono (single sound RCA)
4. COAX (cable) which most DVD players don't have.
All RCA connections on devices should be center color coded And grouped by connection Video 1 Video 2 ect.
Region code hack posted by mairel, December 18 2007: A
greeting to all, good after point to look for and to break the head, I
could convert to multizona my DVD, I count them that I stay fillet.
here they go them the procedures, I hope it serves them. 100%
guaranteed.
1. Turn on
2. Open the tray
3. Press 0000 in RC
4. Change to any region you want 0 for region free
5. Press Pause
6. Turn off
7. Turn on again and enjoy
Power On the player Be sure there is no disk in the player Press the SETUP key on the remote control Go to the General Preference Group Setup (press right key 3 times) Press the keys "1379" slowly one after the Other. A new window (Overlay) will show the current region code Select the desired region code with the “up” or “down” key ( ZERO =CODE FREE) Press PLAY to confirm your selection Press SETUP key to exit.
I finally found a code that works. Code 3144 worked. I am using the RCA universal remote control RCR412S and RCA DVD player DRC200N. The code 3144 is listed under Memorex in the code book that came with the remote control.
