Question about Kenwood KDC-MP208 Car CD/ MP3 Player
No AM radio?
I installed the radio (KDC-MP208) per instructions with all the wiring done as instructed. Antenna is in the unit, FM stations work fine. I just don't get any AM stations. Any ideas? Can't find any support on the problem.
Thanks
  • Anonymous Feb 11, 2009
    I have the 238 model with the same problem???
  • 3 Answers
Try pressing down on the directional pad located on the right side of the stereo, this should bring you to the AM setting. If that doesn't work, make sure you have the proper antenna cable installed as well as the proper wiring harness.
Posted on Sep 14, 2009
How do I fix the factory radio-antenna situation where I have no AM radio, when FM works fine?
If you pick up FM. It isn't the antenna. It's an internal radio problem.
Aug 11, 2015 | Cars & Trucks
Just performed a new install on this. Everything powers up and works fine, including the power antenna. Followed set up instructions including selecting speaker output but no sound at all? Radio station...
It sounds like you may have the negative and positive polarity wrong usually to the speakers. I suggest to use black for negative and red for positive so that each speaker is correct. Speaker wire is good but for self installs its a common mistake.
Oct 23, 2013 | Kenwood KDC-HD455U
AM radio quit working but FM okay
bad radio. FM is harder than AM
but do try , 1 thing
remove the antenna plug from radio jack.
then add a 3foot long insulated wire, any wire
to the inside center jack pin, forming a temporary antenna.
no AM now? , then bad radio.
good now?, your antenna is bad.
Apr 04, 2013 | 2008 Suzuki SX4
Have a kdc-x596, just installed and in the seek mode for AM does not pick up any stations. Locks on to FM fine. What gives?
Sounds like you didn't have the BLUE power antenna wire hooked up. Pull out the radio to confirm. The BLUE wire (from aftermarket radio) will turn on an antenna booster if there is one in the car. What car is this in?
Dec 23, 2012 | Kenwood Excelon KDC-X596
Where can i plug my ipod in to my jensen 9410 dvd mp3 receiver
here is what you can use take a rca cable to 3.5 mm cable
thumbnail.aspx?q=410222334008&id=874e2170e5197aa72b7e313258a4fed3 buy a fm modulator
item-3992-5-500.jpg then you can wire up the fm modulator to the jensen radio red power and black ground unplug your antenna from radio plug it into fm modulator and then connect antenna of fm modulator into your jensen radio antenna spot . the connect the rca cables to the fm modulator and then other end into the ear phone piece on ipod . follow the instruction that come with fm modulator you will have to tune your radio to a station like 88.9 or which ever you pick from the select ones fm mod gives you to hear you ipod . http://www.tintingbyfredjohnson.com
Dec 28, 2010 | Jensen VM9510 Car DVD Player
Just bought a car and it had hardwired sirius radio already installed. I called and activated it with Sirius radio and tried to get assistance from them on how to get it to work. They gave me instruction...
The "hard wired" version that you speak of apparently only refers to the power supply.Do you have a seperate display for the Sirius unit? Now, you failed to mention the type of radio (factory or aftermarket); so, if you have to use an "empty radio station" then you have an FM modulator. This modulator could wired or wireless. The wired version interrupts the vehicle antenna wire and the station on said modulator is usually preset to either 88.1, 88.3,88.7, or 89.1. There is no need to power this modulator up, it comes on when then Sirius comes on. One way to check for power is to turn on the Sirius unit and tune your radio to an occupied Fm station. Wait a few seconds and listen to the reception. Turn off the Sirius unit, the reception should improve for the occupied station. If it is a wireless FM modulator it also has preset stations that you can change but, extending the wieless antenna will greatly improve your reception of the Sirius stations.
Sep 17, 2010 | Sirius Car Audio & Video
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    The FM tuner picks up only a few stations and those are very faint. Two other Proton model 320 radios work fine in the same area. I live on Long Island where the reception is rather strong.
    The tuning module within the radio is getween the base circuit card and the display. A shot of tuner cleaner into one of the ports will usually bring back the FM performace (I just got done diong my own). Also, it goes without saying that you need to make sure your radio still has its antenna wire and that the vacuum didn't eat it. If this is beyond your skill level, find a computer geek (there are few radio geeks any more). Commercial repair would cost more than the value of the radio.
    Jun 11, 2010 | Proton R5A Clock Radio
    Wiring diagram
    My fault meant this as a solution post....
    What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
    Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
    No AM long wave radio
    The antenna wire could be loose.
    Jul 17, 2007 | Kenwood KDC-3021 CD Player
    Kenwood KDC-MP208 Car CD/ MP3 Player Logo
    83 people viewed this question
    Top Kenwood Car Audio & Video Experts
    xxxxxx xxx
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
