Question about Harman Kardon AVR 300 Receiver
How do i connect my subwoofer to my tv
I have surround sound need to know how to hook up subwoofer
  • Anonymous Apr 23, 2009
    i have a seperate subwoofer but how the hell do i connect 2 my tv
  • 57 Answers
Have you tried connecting an AV cable from yoursuboofer to your TV?
If so, what type of connection cable does your Woofer have?
Is your subwoofer apart of a surround sound system or is a separate unit?
Posted on Feb 10, 2009
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
I want surround sound. How do I hook up my audio 5.1 RVC-884VBK, with my HDbox and LCD TV? It's too confusing. What hooks to what? Currently the HD box and blueray DVD is hooked straight to TV ...
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
Jun 26, 2010 | JVC RX-884V Receiver
WD-73837 73 in. HDTV TV: hook up the coaxial cable from the tv to the recei...
7.1 surround sound will not work with a coax connection OR Composite (yellow video with Red and White audio). You either need to use an HDMI cable or the Component connection (Red, Green, and Blue connection along with the Red and White audio or the optical audio connection).
May 18, 2010 | Mitsubishi WD-73837 73 in. HDTV
I bought the sony bdv e500w surround sound and hooked up a optical audio to my tv and that is a sony bravia but it will not work with the surround sound when i hook it up using regular audio cords it works...
im having the same problem, except im connected via audio components and hdmi...cant get sound through the speakers when the TV is on, it doesnt make any sense.
Feb 14, 2010 | Sony Audio Players & Recorders
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
Center and rear speakers not working
In regard to the rear speakers, my system is an LG and the rear speakers will only work if the format that i'm watching (TV, DVD) is in Dolby surround sound 5.1. Normal tv will not give you surround sound unless it says otherwise, usually it will flash up on the screen at the start of the show. So test the unit with something that you know is in 5.1
Jun 26, 2009 | Audio Players & Recorders
How to hook up wii to surround sound
You need to connect your amplifier to your TV, (Video Out of Amp to video In of TV), then select the input where you connected your WII in amp.
Or you could just connect the yellow plug to the TV directly, and the white and red plug to your amplifier.
A note thou, Red and White will not give "True" surround sound as it has only 2 channels, you need to connect a digital input to the amp to get true surround.
Let me know what happens
Mar 15, 2009 | 2006 Chevrolet Uplander
We have a Sony Trinitron and a Sony STR-K670P. We use to have it hooked up to a DVR, but now we went down to basic cable. I can't seem to get sound to come through my surround system. Any advise out there?...
if your trying to use the dvr still your probably not connecting it all properly. make sure that. having a sony trinitron you have alot of connections on the back. if you connect all of the accessories that you have on your tv directly into each input and use the tvs main output connection to connect straight to your surround sound. this should fix your problem. plus you wont have a bunch of stuff hooked up to your surround sound receiver
Feb 21, 2009 | Sony Audio Players & Recorders
Connection a JBL surround cinema speakers with sub to a Yamaha
if you do not have the digital hook up from the tv to the reciever
304c659.gif then you will not get the subwoofer sounds or the dolby digital sounds
if you don't have this on your tv then just turn off the dolby digital when watching the tv , and you should be able to hear the subwoofer thru the virtual surround sound
hope this info is worth a fixya and if you need other help then just ask me and
i'll be glad to help
Nov 23, 2008 | Yamaha HTR-5850 Receiver
Harman Kardon AVR 300 Receiver Logo
520 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
