Question about Creda W100FW Front Load Washer
Washer functions correctly but water does heat up?
Programmes seem to run ok.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Does it heat the water? may be a heater or thermister problem.
Posted on Feb 11, 2009
Wash programmes not changing
Unless meets water from tank necessary to check the pumps a discharge and clean him from rubbish.
Nov 12, 2013 | Hotpoint WMA46 Front Load Washer
Just brought an LG F1256QD washing machine and looked through the owner's manual but it doesn't seem to have times for wash loads. Is there any indication on timings for programmes? Just put on a...
If it is a new washer (you didn't say) it is likely to be working correctly.
If it is NOT a new machine it is possible that the heater is taking longer than it should to heat the water to the correct temperature. This could be that the element is coated in calcium. I suggest you run the contents of a couple of sachets of proprietary limescale removing powder/fluid through it. The most efficient way is to put the contents in an empty washer and pour a kettle of hot water into the drum then leave overnight. In the morning run just a spin; the water mix will then go through the drain filter and drain motor impeller blades, doing absolutely NO harm whatsoever, in fact some good!
You could also consider repeating the action ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 19, 2011 | LG Washing Machines
Only takes on cold water will not take on hot when you disconnect pipe hot water runs through so supply is ok
If it is a hot and cold fill washer with 2 seperate inlet hoses, and no hot is entering, then either the hot inlet valve is faulty, or the valve is not getting an electric feed to it.
Make sure that the programme you select is ahot prog, as many of the programmes are3 cold fill only.
Mar 28, 2010 | Hotpoint WMA58 Front Load Washer
I have a whirpool washing machichine the creaion model. I was wondering if needs a hot water supply or is it ok to use a y shaped hose.
If you have a hot water supply then use it otherwise use a Y hose to connect the cold supply to both hot and cold inlets. Machines are generally made with cold only inlets today as most washing detergents are formulated for cooler washing temperatures and the mfrs say that it is more convenient and cheaper to heat what is required rather than draining your domestic hot water tank. There will not be a problem with using cold fill to both inlets but you can expect some of the hotter was programmes to take longer than expected as the water will have to be heated in the machine to allow the programme to run correctly.
Oct 02, 2009 | Whirlpool Washing Machines
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Is it OK to run a washer without water
All you can test without water, is the spin and pump functions..
The heater and the wash action will not work without the correct amount of water in the washer.
Hope this helps.
Plz rate my solution.
Thanks
Jan 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Hotpoint Dishwasher
have you tried adjusting the feet on the front of the washer so it is tilted back slightly .This will stop the water from coming over the little lip on the front of the machine. Some dishwashers also use a little amount of water in the bottom when drying asthis helps to curculate the heat ; leave the washer to complete it's cycle and it should beep to let you know when it is finished
Dec 09, 2007 | Dishwashers
Front-loading washing machine
Kink in the filler hose Water level sensor blocked[as you cleaned the filter, did you do this one?]
Jul 24, 2007 | Hotpoint Aquarius WD63 Front Load...
Creda W100FW Front Load Washer Logo
70 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
