Question about Philips 52 In. LCD HDTV
Philips 42" HDMI connection to VGA on laptop connection problems
Went about getting a cable to connect my philips 42" hd tv to my dell laptop.My laptop only has a vga connection and does not have a dvi connection.Went to a couple of computer and tv stores and was told they are not made. Checked on line and got a hdmi to vga direct cable.I am still having problems getting the picture to change from laptop to tv.Constant black screen when hdmi channel is switched on and laptop connected. FN and F8 pressed to swap from laptop monitor to external monitor and screen just flicks to black and back to normal screen and no change to tv screen.
Any information would be grateful
  • P_E_T_E_R_84 Feb 11, 2009
    my tv is not exact same model as yours mate but it is a phillips i think it might be a fault with all their hdmi ports on tellys i personally think it is a joke paying almost £1000 and not getting the full potential it has disgusted me
  • omahonykeith Feb 18, 2009
    I was speaking to a guy in the IT department where i work and he says the problem is the signal from the vga on the laptop is an analogue signal and the signal the tv needs is a digital signal.Because phillips dont have an analogue connector in their tvs (as most others do) your laptop needs to have a dvi connection.But there is a convertor you can buy to change the signal.**** that im not buying a new laptop or tv or converter theres a recession on at the moment ha!
    New Friend:
  • 90 Answers
Why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Posted on May 25, 2009
Kenzmailroom: the whole problem is that the philips tv's DO NOT have a vga input so that is really an irrelevant "solution"
I think the best solution would just use S-video cable (assuming your laptop has an S-video out).
Posted on Feb 16, 2010
How do i get audio to philipspfp5332d/37 using hdmi2 vga converter when tv input is locked in safemode
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=us&ctn=50PFP5332D/37
frequenly asked questions- you will probably need to also use an aux sound input in conjunction with a video cable if you are not using an hdmi connection, read the article above for confirmation.
Feb 01, 2015 | Dell Computers & Internet
Can not connect hdml wire to my philips led tv with my dell laptop. what to do
If your laptop does not have a HDMI port then you need a VGA to HDMI converter. Connect this converter to your laptop and then connect it to the TV using a HDMI cable. You also need to connect the audio out port on the laptop to the audio in on the TV. You can get a combined audio input with some HDMI converters.
Check out this WEB site.
http://www.proaudiovisual.com.au/vga-to-hdmi-converter-adapter-and-upscaler-video-audio-full-hd-1080p/
Mar 05, 2013 | Computers & Internet
I have a del latitude E6410 laptop and would like to know how to connect it to a pansonic 42 flatscreen hdtv to use it as a moniter
Dell Latitude E6410 does not offer HDMI or DV. Only VGA Port is available. Therefore in order to connect the laptop with the TV, you can use VGA cable.
But if the VGA input is not available on the TV, you need to get VGA-to-DVI or VGA-to-HDMI Adapter, depending upon the type of port available on the TV.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Aug 18, 2011 | Panasonic Computers & Internet
How do i connect a pc to my 42pfl 5522d
in most cases you must have a video card that supports tv.s will have a special plug in it and a cable
Mar 03, 2010 | Philips 42PFL5332D 42 in. LCD Television
What kind of connector do I use to connect a dell laptop to a Hitachi 42'' plasma display? HDMI to DVI or HDMI to VGA?
If the TV has a VGA connector then use a VGA to VGA cable from your laptop as most laptops have a VGA output. Otherwise use one of the other combinations that work HDMI to DVI or HDMI to HDMI..
Nov 11, 2009 | Televison & Video
Sansui 42'' HDMI problem
howto get the hdmi signal thro hdmi to dvi cable in plasma pdp42 sansui tv in dvi input
May 03, 2009 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Philips 52 In. LCD HDTV Logo
3,459 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
