Question about Hitachi Televison & Video
VCR HOOKUP PROBLEM
I can get the converter to work thru the tv, but we have been using our vcr thru the home stereo for surround sound. Everytime I turn on the VCR it  goes to analog and cannot get a digital signal. We also were getting 6 chanels before and only 4 now and 1 is different so we only get 3 of our original channels. We no longer have NBC or ABC.
  • djp49657 Feb 11, 2009
    I have it hooked up this way. The tv works ok if I use the tv speakers and don't turn on the vcr. If I want surround sound, and turn on my vcr the converter does not work and  have to go to analog bypass mode to get good analog reception and surround sound.
  • Hitachi Master
  • 520 Answers
The hook up should be antenna then converter box then vcr then tv. We will need more info if this doesn't solve the problem. Hope this helps. Remember, if your converter box doesn't have an analog pass thru, it will block your analog channels.
Posted on Feb 11, 2009
  • 86 Answers
You will need to hook your signal to the converter box then into your vcr and then into your TV. Now if your vcr has signal out then you will not have any problems hooking your tv up to the vcr. You may have to use the audio out to get the right sound with your tv.
Have Technics SA-EX500 connected to Samsung Smart TV. For tv channels the sound is perfect but when I switch to Netflix or HBOGO the sound is static/cackling.
Suggest connecting via the headphones jack or if available the RCA audio output jacks. If you connect via the headphone jack you will need to adjust the TV volume to a lower setting to avoid distortion/./ The The problem is that the optical output connection is a digital connection and depending on the digital format the Digital to Analog converter may not be a configuration that the audio stream to the stereo required for the tv/vcr in.
How does the audio sound using the Samsung Smart TV internal speakers>
Also under menus/audio/settings you may need to change the Optical output to stereo.
Netflix also has settings that will change the audio stream.
Hope This helps?
Nov 21, 2016 | Samsung Audio Players & Recorders
I want to hookup my insignia converter box to my dvd/vcr and my tv so I can record programs. What do I need to do. I have a 2 year old Toshiba Dlp and an Allegro dvd/vcr
Cable from wall to "cable in" on converter box.
"Cable out" from converter box to "cable in"on vcr. "Cable out" from VCR to TV "Cable IN" DVD should be hooked to VCR by way of Composite cables Red,Left, Yellow, Video White Right. There you go! THanks, Dana
Aug 16, 2009 | Insignia Digital-to-Analog Converter for...
How to Connect Converter to TV, DVD/VCR and a Stereo?
Connect converter box to your DVD/VCR player at the ant in. Depending on your location you might need a new ant for UHF.
Jun 15, 2009 | Philips DVDR3435V/37 DVD Recorder/VCR
Getting my VCR to record from the TV with a converter box hookup
Hook up antenna to converter box then from that out to the vcr's input (red,white, yellow connections are better than coaxial).
Jan 20, 2009 | Insignia Digital-to-Analog Converter for...
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
Question about hookup for Digital to Analog converter TB100MW9
however you like!, I have my converterbox connected to my VCR, then VCR to stereo!, but I have to turn my vcr on to hear it through the stereo of course!
Aug 25, 2008 | Sony RMT-V202 Remote Control
Only works when playing a DVD.
This is an easy and quick fix.
What you will need:
RCA cables (audio)
( possibly Line out converter )
Your television is either going to need Video Out, or if you have a VCR or VCR/DVD combo connected to your television. Assuming that you have a VCR combo, the way your tv should be set up is on the back of the vcr combo, your cable will run into the coaxial IN and then you have another cable running from Coaxial OUT to your tv. If you have it set up like this, then the DVD / VCR combo will have RCA Audio / video out ports on the back side. Run RCA cables from the DVD / VCR output to the surround sound INPUT. If you already have your inputs in use on the surround sound, Radioshack has RCA splitters for about $1.50 each, you might need to pick some of them up so you dont have to go through the trouble of reaching behind it all the time to disconnect and reconnect whatever your trying to connect. Now if you dont have the DVD / VCR combo, then your TV "MUST" have RCA Outputs. if it doesnt, then the only way that your going to have your surround sound connected to your tv is to take the TV apart and get a RCA "Line output converter" and wire it to the left / right channels of your tv. From what I've read, i think this is what your trying to do so I hope this helps
Feb 19, 2008 | Durabrand STS92 System
I want to connect my sound system to my tv
Jan 20, 2008 | Durabrand STS92 System
Televison & Video Logo
108 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
