Question about Zanussi WJS1265W Front Load Washer/Dryer
How to fit a door seal on zanussi washer dryer WDT 1085
How do I fit the new door seal on my Zanussi washer dryer model number WDT1085
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
Fitting new door seal
Hello,you mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install
Thanks
May 28, 2010 | Zanussi FS1155W Front Load Washer
IS IT EASY TO REPLACE THE DOOR SEAL/GASKET ON ZWF1430W
it is very very difficult to replace the door seal on a zanussi washing machine, its best fitted by an engineer
Feb 03, 2010 | Zanussi ZWF1430W Front Load Washer
How to fix iner seal on the oven door
I have a Zanussi ZDF290X which requires a new top oven seal. I have pulled the remainns of the old one out, but without dismantling the oven it seems impossible to fit the new seal. Any easy way of fixing this, please?
Jan 13, 2010 | Zanussi Ovens
Belt broken on my wdt1085 washing machine.
take off back plate to washer, wrap belt round motor and spider (6 legged wheel above the motor) and turn the spider thats it
Jun 23, 2009 | Zanussi F1045W Front Load Washer
Trying to fit new door seal with spring keeper to washing machine
Fit the seal first and then fit the spring,it cannot be done with the spring fitted on the seal first.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Removing/replacing main drum bearing on a zanussi WDT1085
Yes you do need to remove the drum, it entails stripping the washer down, and it is normal practice to replace the complete drum half with the bearings pre-fitted..
It is not a job to undertake, unless you feel competent to do do it, as it entails al ot of work and time..
Good luck if you decide to proceed.
Plz rate my suggestions.
.Thanks.
Jan 03, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Fitting a new door seal
unplug machine. Pull off retainer clip from the front , with both hands inside push up the seal untill its free. Then with the new seal apply washing up liquid to the gap on the seal. And fit this is fiddly. Then pull the spring you removed to loosen abit and with a screw driver to keep it in place throught the door lock thats why youve unpluged it. strech the spring around. the ease on the front part of the seal and replace the clip. put on a wool wash to check for leaks. appliance doctor
Feb 05, 2007 | Zanussi IZ161S Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
558 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
